On Apr 6, 2012, at 7:46 AM, haquin wrote:
> Hi,
> - I don't understand why the Linux IOC crash is not reproducible ...
> so now the behaviour is the same on both Linux and VxWorks:
> Data in the waveform are equal to zero if scan is I/O Intr
> Data are correct in the waveform if scan is periodic
> - I've successfully tested the read INT32_LE function.
> I don't manage to write a FLOAT32_LE:
> here is my record:
> record(ao, "$(EQPT):TstICons") {
> field(SCAN, "Passive")
> field(DTYP, "asynFloat64")
> field(OUT, "@asyn($(EQPT):Write_IConsFLE 0)FLOAT32_LE")
What does SCAN=I/O Intr mean for output records? Is that even supported?
> here is my drvModbusAsynConfigure:
> drvModbusAsynConfigure("AR-GT7-PC3:Write_IConsFLE","AR-GT7-PC3", 255, 16 , 5 , 2 , 7 , 1 , "InterfaceIocaste")
> do you see any incorrect setting ?
The arguments to drvModbusAsynConfigure are
drvModbusAsynConfigure(portName, "AR-GT7-PC3:Write_IConsFLE",
tcpPortName, "AR-GT7-PC3"
slaveAddress, 255
modbusFunction, 16
modbusStartAddress, 5
modbusLength, 2
dataType, 7
pollMsec, 1
plcType); "InterfaceIocaste"
A one millisecond polling interval seems rather short. Perhaps things simply don't have time to finish processing at that rate.
Records using the new drvUser feature (e.g. the FLOAT32_LE in the OUT field shown above) can specify the registers as dataType=0 -- this is handy since you can mix integer and floating values in a single I/O block.
Eric Norum
[email protected]
- RE: Proposed support for additional Modbus data types Mark Rivers
- Proposed support for additional Modbus data types Mark Rivers
- Re: Proposed support for additional Modbus data types haquin
- Re: Proposed support for additional Modbus data types Eric Norum
<2012>
2025
2026
<2012>
2025
2026
