1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Stream Device parsing strings
To: [email protected]
Date: Thu, 12 Apr 2012 12:39:10 +0200
Rod,
the "Separator" variable sets the separating character when reading
*array* data into waveform records. (So that it works with any number of
elements.)
In your case of non-array data, just use semicolon characters at the
appropriate positions inside the format string.
Good luck,
~Ralph
On Thu Apr 12 2012 00:01:39 GMT+0200 (CEST), Rod Nussbaumer
<[email protected]> wrote:
> Hi all.
> I am trying to get streamDevice to break an input string that has
> fields delimited with semi-colons into discrete strings. The input
> string as read by asyn + GPIB looks something like
>> BIN;RI;MSB;4;32;500;Y;100.00000000000E-12;20.90000000000E-9;"s";0.05000000000;5.00000000000E-9;21.00000000000E-9;0.00500000000;232.83064365387E-12;0.0000;"V";"C2,
>> 50.00mV/div, 5.000ns/div,500 points, Sample mode";"C2"
> My stream device protocol looks like:
>> WFMPRE {
>>     ReplyTimeout = 200;
>>     ReadTimeout = 50;
>>     InTerminator = LF;
>>     Separator = ";";
>>     out "VERBOSE ON";
>>     out "WFMO?";
>>     in
>> "%(\$1PARAM01.VAL)s%(\$1PARAM02.VAL)s%(\$1PARAM03.VAL)s%(\$1PARAM04.VAL)s%(\$1PARAM05.VAL)s%(\$1PARAM06.VAL)s%(\$1PARAM07.VAL)s";
>>     out "VERBOSE OFF";
> where the records referred to by $1PARAMxx.VAL are stringout records
> with SoftChannel DTYP. Each successive conversion ends at either the
> 39th converted character, or the first whitespace. It seems to be
> completely ignoring the specified separator. Is this correct behavior?
> If so, any suggestions for accomplishing what I want (ability to
> access the string fields as records or as string elements of a
> waveform record. I intend to add more field conversions to complete
> the string parsing, if/when I get this much working.
> The data in question comes from a Tektronix scope, and contains the
> data need to convert a generically scaled waveform array into an array
> scaled to engineering units.
> Thanks.
> Rod Nussbaumer
> ISAC Controls, TRIUMF
> Vancouver, Canada.
Re: Stream Device parsing strings Rod Nussbaumer
Prev: Stream Device parsing strings Rod Nussbaumer
Next: Announce: sequencer release 2.1.6 Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Stream Device parsing strings Rod Nussbaumer
