Hi all.
I am trying to get streamDevice to break an input string that has fields
delimited with semi-colons into discrete strings. The input string as
read by asyn + GPIB looks something like
BIN;RI;MSB;4;32;500;Y;100.00000000000E-12;20.90000000000E-9;"s";0.05000000000;5.00000000000E-9;21.00000000000E-9;0.00500000000;232.83064365387E-12;0.0000;"V";"C2, 50.00mV/div, 5.000ns/div,500 points, Sample mode";"C2"
My stream device protocol looks like:
WFMPRE {
ReplyTimeout = 200;
ReadTimeout = 50;
InTerminator = LF;
Separator = ";";
out "VERBOSE ON";
out "WFMO?";
in "%(\$1PARAM01.VAL)s%(\$1PARAM02.VAL)s%(\$1PARAM03.VAL)s%(\$1PARAM04.VAL)s%(\$1PARAM05.VAL)s%(\$1PARAM06.VAL)s%(\$1PARAM07.VAL)s";
out "VERBOSE OFF";
where the records referred to by $1PARAMxx.VAL are stringout records
with SoftChannel DTYP. Each successive conversion ends at either the
39th converted character, or the first whitespace. It seems to be
completely ignoring the specified separator. Is this correct behavior?
If so, any suggestions for accomplishing what I want (ability to access
the string fields as records or as string elements of a waveform record.
I intend to add more field conversions to complete the string parsing,
if/when I get this much working.
The data in question comes from a Tektronix scope, and contains the data
need to convert a generically scaled waveform array into an array scaled
to engineering units.
Thanks.
Rod Nussbaumer
ISAC Controls, TRIUMF
Vancouver, Canada.
- Re: Stream Device parsing strings Ralph Lange
Re: DCT flag in record reference manual Andrew Johnson
<2012>
2025
2026
RE: DCT flag in record reference manual Abadie Lana
<2012>
2025
2026
