1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: DCT flag in record reference manual
To: Andrew Johnson <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 12 Apr 2012 17:53:55 +0200
Thanks all.
Lana
-----Original Message-----
Sent: 11 April 2012 22:28
To: [email protected]; Abadie Lana
Subject: Re: DCT flag in record reference manual
Hi Lana,
On 2012-04-11 Lana Abadie wrote:
> 2.TSE field is also marked DCT=no. So again what does it mean? and if
> it is  not advised to use in db file then what is the proper way to implement it?
>  via TSEL field?
Bob Dalesio replied:
> ----I believe that is right.
> Database Configuration Tool (DCT), was the tool for configuring these
> in  the dark ages. Where this field was set to no, it meant that it
> was not to  be configured as the initialization and operation of that
> record would  overwrite the field. Therefore, the value set in by the
> loaded database  would never be used.
Nowadays having DCT=no doesn't really mean much, since we don't have to use the dct program any more to create ASCII databases.  You can set fields that have DCT=no in your .db files with no ill effect, but an EPICS-aware database design tool like VDCT doesn't have to make those fields available to you.
There should be little need for it to do so though, since the initial values of fields marked DCT=no are usually ignored and get overwritten by the record support code.
In the particular case of the TSE field though, that should be marked as DCT=yes in R3.14.x since it has a promptgroup() setting in the dbCommon.dbd file (in 3.13.x it did not).  I'll fix the record reference manual.
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
DCT flag in record reference manual Abadie Lana
RE: DCT flag in record reference manual Dalesio, Leo
Re: DCT flag in record reference manual Andrew Johnson
Prev: [Fwd: Re: Stream Device parsing strings] Dirk Zimoch
Next: Re: Stream Device parsing strings Rod Nussbaumer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: DCT flag in record reference manual Andrew Johnson
Next: Stream Device parsing strings Rod Nussbaumer
