Hi Lana,
On 2012-04-11 Lana Abadie wrote:
> 2.TSE field is also marked DCT=no. So again what does it mean? and if it is
> not advised to use in db file then what is the proper way to implement it?
> via TSEL field?
Bob Dalesio replied:
> ----I believe that is right.
> Database Configuration Tool (DCT), was the tool for configuring these in
> the dark ages. Where this field was set to no, it meant that it was not to
> be configured as the initialization and operation of that record would
> overwrite the field. Therefore, the value set in by the loaded database
> would never be used.
Nowadays having DCT=no doesn't really mean much, since we don't have to use
the dct program any more to create ASCII databases. You can set fields that
have DCT=no in your .db files with no ill effect, but an EPICS-aware database
design tool like VDCT doesn't have to make those fields available to you.
There should be little need for it to do so though, since the initial values
of fields marked DCT=no are usually ignored and get overwritten by the record
support code.
In the particular case of the TSE field though, that should be marked as
DCT=yes in R3.14.x since it has a promptgroup() setting in the dbCommon.dbd
file (in 3.13.x it did not). I'll fix the record reference manual.
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
- RE: DCT flag in record reference manual Abadie Lana
- DCT flag in record reference manual Abadie Lana
- RE: DCT flag in record reference manual Dalesio, Leo
Stream Device parsing strings Rod Nussbaumer
<2012>
2025
2026
<2012>
2025
2026
