> One simple idea would be to add a bit to the asynTrace flags,
> ASYN_TRACE_NOREPEATS. The asynTrace facility could remember the
> previous error message for a particular pasynUser, and if the next one
> is the same (except for the time stamp) then the message would not be
> output.
The drivers would then need to decide when to reset that flag, to print the message again. For example, if a comms error was resolved, but re-occurred again (say, an hour later). You would want a new message in that case.
Seems like, in general, people wouldn't mind this functionality in the errlog layer. Perhaps as Nick suggested as a library that implemented the same interface, and was plugged in somehow. Or, could modify errlog by adding a function call in each function, that checks the message and rejects or accepts it.
Cheers,
Matt
> This would make it easy for asyn drivers to adhere to the Dalesio rule
> with no changes to the driver at all, just a change in the startup
> script.
> Mark
> From: [email protected] [[email protected]] on
> behalf of Ralph Lange [[email protected]]
> Sent: Wednesday, April 18, 2012 3:38 AM
> To: [email protected]
> Subject: Re: log message filter in Asyn
> Hm...
> so it is not really the same issue, as in Mark's case (I assume)
> procServ is doing the logging while in your case (I assume) console is
> doing it.
> Which shows adding the filter to procServ or console is a bad idea, as
> it would have to be reimplemented for every client people use to access
> their IOCs.
> Eric is safe when holding to his opinion, as there is no log server
> involved in both cases.
> Maybe the errlogPrintf layer should define a plugin API for such
> filters, and allow adding filtering either general (for all loggers and
> the console), or for each configured logger. (To allow no-filtering
> connections to log servers that are ready to take all the crap.)
> If I remember correctly, the Dalesio test (R) for drivers included
> pulling and reconnecting the device cable from the IOC, and demanded
> that the driver log each of these actions with exactly one log message,
> and no secondary resulting messages inbetween.
> With all due respect, Asyn would fail this badly.
> Cheers,
> ~Ralph
> On 17.04.2012 19:27, [email protected] wrote:
> > Hi,
> > We have the same issue that Mark described, in that we're using
> procServ along with conserver to log from our IOCs. I agree that
> filtering should be part of any log server. But I think there's a place
> for it in clients too. For example, we already do rate limiting of
> alarms from records using things like hysteresis fields.
> > Yes, Asyn itself probably isn't the best place for it though.
> > Cheers,
> > Matt
> on behalf of Eric Norum [[email protected]]
> > Sent: 17 April 2012 16:39
> > To: [email protected] Talk
> > On Apr 17, 2012, at 8:26 AM, Mark Rivers wrote:
> >> You can also turn off asynTrace messages for a particular device
> with
> >> asynSetTraceMask(port, addr, 0)
> >> But I see the utility of what Matt is proposing. We use procServ to
> run our IOCs, both soft IOCs and vxWorks IOCs. On vxWorks the procServ
> is controlling a telnet session to an Ethernet terminal server, which
> is connected to the vxWorks console port. For logging we just use the
> log file capability of procServ, not a special logging program. If a
> device becomes unavailable the log file can quickly grow very large
> with asynTrace error messages.
> >> Of course we could manually set the asynTrace mask to 0, as shown
> above. But it would be nice to have the capability that Matt proposes,
> to automatically reduce the number of messages in the log file if they
> are all just repeats.
> > Agreed, but I'm holding to my opinion that this capability belongs in
> the log server, not in all the log clients. It certainly does not
> belong in the ASYN layer. In the errlogPrintf layer, perhaps, but
> really this belongs in the log server.
> > Eric Norum
> > [email protected]
- RE: log message filter in Asyn Mark Rivers
- Re: log message filter in Asyn Benjamin Franksen
- log message filter in Asyn matthew.pearson
- Re: log message filter in Asyn Andrew Johnson
- Re: log message filter in Asyn Eric Norum
- RE: log message filter in Asyn matthew.pearson
- Re: log message filter in Asyn Ralph Lange
<2012>
2025
2026
<2012>
2025
2026
