1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: [StreamDevice] need advice
To: EPICS Tech Talk <[email protected]>
Date: Thu, 26 Apr 2012 19:26:14 +0400
Dear all,
I have a Tektronix scope (TPS2024). I am using StreamDevice. I know how to set the scope's parameters. These are simple commands with the SCAN field = PASSIVE.
One record (the Trigger Single Sequence button) is causing me some pain. When the scope is triggered (end of measurement), I need a readback signal to change its state (=0).
So far my commands were only one way (except for the initializaion). I send, nothing comes. Here is what I use:
record(bo, "$(P)$(R)TrigArm") {
  field(DESC, "Arm the trigger")
  field(SCAN, "Passive")
  field(DTYP, "stream")
  field(OUT, "@devTPS20xx.proto TrigArm $(PORT) $(A)")
  field(ZNAM, "STOP")
  field(ONAM, "ARMED")
  field(PINI, "")
TrigArm {
    ReplyTimeout = 2000;
    out "ACQ:STOPA SEQ";
    out "ACQ:STATE %{OFF|ON}";
    @init {
        out "ACQ:STATE?";
        in "%i";
So I need the same @init code in the TrigArm protocol (out "ACQ:STATE?";in "%i";). How can I do that?
The "ACQ:STATE?" command will have an answer ("1"=Trigger Armed, "0"=Trigger Not Armed).
I have tried using another record (with forward link), but to no avail.
Best regards,
Pavel Maslov, MS
Controls Engineer at Pulsed power Lab
Efremov Institute for Electro-Physical Apparatus
St. Petersburg, Russia
Mobile: +7 (951) 672 22 19
Landline: +7 (812) 461 01 01
Prev: Re: Autosave and RTEMS-4.10 Kate Feng
Next: Re: Autosave and RTEMS-4.10 Kate Feng
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS3.14.12 RTEMS patch for nfsMount() ( was Re: Autosave and RTEMS-4.10) Andrew Johnson
Next: Re: [StreamDevice] need advice Pavel Masloff
