Subject: OK to make function variable in registryFunction.c static?
Date: Mon, 30 Apr 2012 15:25:09 -0600
I was compiling the synApps areaDetector on Cygwin 1.7 under
base 3.14.12.2 using the system libs for netCDF and HDF5 for
fun, but ran into a linker error, complaining that the symbol
"_function" was multiply defined, once in registryIoc.lib and
once in libnetcdf.a.  I tracked the EPICS symbol down to the
"const char *function" variable in BASE/src/registry/registryFunction.c:
const char *function = "function";
static void *registryID = (void *)&function;
Seeing as neither symbols seem to be used outside of that file,
I prepended "static" to the declaration of "*function", recompiled
EPICS, and recompiled areaDetector successfully.  I've only tested
the new base with softIoc, and areaDetector not at all, so by no
means have I adequately tested this hack.  I cannot find any
mention of this particular hack in TechTalk or base Release Notes
or base Known Problems.
Instead, I thought I should ask, is this hack safe (or otherwise
appropriate)?
ru
Ru Igarashi                    Software & Instrumentation Specialist
e-mail: [email protected]   Canadian Light Source
ph:306 657 3751                University of Saskatchewan
fax: 306 657 3535              Saskatoon SK S7N 0X4
Re: OK to make function variable in registryFunction.c static? Andrew Johnson
Prev: Re: [Scopes] BMP image record?? Rod Nussbaumer
Next: Re: OK to make function variable in registryFunction.c static? Andrew Johnson
Prev: RE: AreaDetector Roper or PVCam IOC link problem giles.knap
