Subject: Re: OK to make function variable in registryFunction.c static?
To: [email protected]
Cc: Ru Igarashi <[email protected]>
Date: Mon, 30 Apr 2012 17:01:58 -0500
On 2012-04-30 Ru Igarashi wrote:
> I was compiling the synApps areaDetector on Cygwin 1.7 under
> base 3.14.12.2 using the system libs for netCDF and HDF5 for
> fun, but ran into a linker error, complaining that the symbol
> "_function" was multiply defined, once in registryIoc.lib and
> once in libnetcdf.a.  I tracked the EPICS symbol down to the
> "const char *function" variable in BASE/src/registry/registryFunction.c:
> const char *function = "function";
> static void *registryID = (void *)&function;
> Seeing as neither symbols seem to be used outside of that file,
> I prepended "static" to the declaration of "*function", recompiled
> EPICS, and recompiled areaDetector successfully.  I've only tested
> the new base with softIoc, and areaDetector not at all, so by no
> means have I adequately tested this hack.  I cannot find any
> mention of this particular hack in TechTalk or base Release Notes
> or base Known Problems.
> Instead, I thought I should ask, is this hack safe (or otherwise
> appropriate)?
That symbol should not be globally visible, so your change is perfectly safe
and correct; thanks for pointing it out!  I will fix this for the next
release.
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
OK to make function variable in registryFunction.c static? Ru Igarashi
Prev: OK to make function variable in registryFunction.c static? Ru Igarashi
Next: Re: [Scopes] BMP image record?? Matt Newville
Next: RE: asynPortDriver callbacks to I/O Intr, how to propagate an error? Mark Rivers
