Subject: CSS build with Eclipse RCP-3.7 and -pluginCustomization
To: <[email protected]>
Date: Fri, 18 May 2012 14:28:40 +1000
We are building our own CSS product with RCP-3.7. And I found the -pluginCustomization option does not work any more. I debugged the program a bit more and found the following source code:
org.eclipse.equinox.internal.app.CommandLineArgs (org.eclipse.equinox.app.source_1.3.100.v20110321.jar)
<pre>
// obsolete command line args
private static final String NO_PACKAGE_PREFIXES = "-noPackagePrefixes"; //$NON-NLS-1$
private static final String NO_UPDATE = "-noUpdate"; //$NON-NLS-1$
private static final String BOOT = "-boot"; //$NON-NLS-1$
private static final String CLASSLOADER_PROPERTIES = "-classloaderProperties"; //$NON-NLS-1$
private static final String PLUGINS = "-plugins"; //$NON-NLS-1$
private static final String FIRST_USE = "-firstUse"; //$NON-NLS-1$
private static final String NEW_UPDATES = "-newUpdates"; //$NON-NLS-1$
private static final String UPDATE = "-update"; //$NON-NLS-1$
private static final String PASSWORD = "-password"; //$NON-NLS-1$
private static final String KEYRING = "-keyring"; //$NON-NLS-1$
private static final String PLUGIN_CUSTOMIZATION = "-pluginCustomization"; //$NON-NLS-1$
</pre>
So it seems -pluginCustomization is obsolete. But I can't find what I should use instead. Am I missing something? Has anyone else encountered this problem?
Thanks
Xinyu WU
ASKAP Computing
Australia Telescope National Facility
CSIRO Astronomy and Space Science
phone: +61 2 9372 4727
postal: PO Box 76 Epping, NSW. 1710
Re: CSS build with Eclipse RCP-3.7 and -pluginCustomization Kasemir, Kay
Prev: Re: stream device driver parse question Rod Nussbaumer
Next: Re: cPCI express Urša Rojec
Prev: RE: [EDM] on windows? Steiner, Mathias
Next: Re: CSS build with Eclipse RCP-3.7 and -pluginCustomization Kasemir, Kay
