1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CSS build with Eclipse RCP-3.7 and -pluginCustomization
To: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 18 May 2012 08:29:12 -0400
Hello:
I'm using Eclipse 3.7.2 with the same org.eclipse.equinox.app 1.3.100 and
the -pluginCustomization works fine.
The big caveat is that there's no error message if the file cannot be
found because
a) typo in the file name
b) path not as expected
When Eclipse is started, the 'current' directory may not be the one where
you started CSS, so it's important to always use
-pluginCustomization /with/the/full/path/to/the/settings.ini
I wasn't aware about the obsolescence, but you're correct, it's mentioned
in the source comment.
For 3.7, however, -pluginCustomization is still listed in the online help
as a valid command-line option, and I just checked 4.2M7, a preview of the
upcoming Eclipse 4.2 release, where CommandLineArgs is also unchanged:
"obsolete" but still there.
As an alternative, you can also set the property
eclipse.pluginCustomization.
Maybe the designated option -pluginCustomization will eventually be
replaced by -Declipse.pluginCustomization, just setting a property?
Change being the only constant, this might require future adjustments in
scripts that start RCP apps.
Kay
On 5/18/12 24:28 , "[email protected]" <[email protected]> wrote:
>Hi,
>We are building our own CSS product with RCP-3.7. And I found the
>-pluginCustomization option does not work any more. I debugged the
>program a bit more and found the following source code:
>org.eclipse.equinox.internal.app.CommandLineArgs
>(org.eclipse.equinox.app.source_1.3.100.v20110321.jar)
><pre>
>// obsolete command line args
>private static final String NO_PACKAGE_PREFIXES = "-noPackagePrefixes";
>//$NON-NLS-1$
>private static final String NO_UPDATE = "-noUpdate"; //$NON-NLS-1$
>private static final String BOOT = "-boot"; //$NON-NLS-1$
>private static final String CLASSLOADER_PROPERTIES =
>"-classloaderProperties"; //$NON-NLS-1$
>private static final String PLUGINS = "-plugins"; //$NON-NLS-1$
>private static final String FIRST_USE = "-firstUse"; //$NON-NLS-1$
>private static final String NEW_UPDATES = "-newUpdates"; //$NON-NLS-1$
>private static final String UPDATE = "-update"; //$NON-NLS-1$
>private static final String PASSWORD = "-password"; //$NON-NLS-1$
>private static final String KEYRING = "-keyring"; //$NON-NLS-1$
>private static final String PLUGIN_CUSTOMIZATION =
>"-pluginCustomization"; //$NON-NLS-1$
></pre>
>So it seems -pluginCustomization is obsolete. But I can't find what I
>should use instead. Am I missing something? Has anyone else encountered
>this problem?
>Thanks
>Xinyu WU
>ASKAP Computing
>Australia Telescope National Facility
>CSIRO Astronomy and Space Science
>phone: +61 2 9372 4727
>postal: PO Box 76 Epping, NSW. 1710
CSS build with Eclipse RCP-3.7 and -pluginCustomization Xinyu.Wu
Prev: Re: stream device driver parse question Dirk Zimoch
Next: [CA][waveform]max array bytes on IOC Pavel Masloff
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: CSS build with Eclipse RCP-3.7 and -pluginCustomization Xinyu.Wu
