1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: On compatibility
To: <[email protected]>, <[email protected]>
Cc: [email protected], [email protected]
Date: Tue, 29 May 2012 09:05:52 +0000
I'm going to quote the entirety of Dirk's message.
> I like backward compatibility. This allows to take care only of the
> changes that I really need.
> When upgrading to a new version of a certain (3rd party) driver, I
> usually spend some time on tracking the changes. I do that because of
> bad experience. Drivers change behavior, change APIs and so on. Recent
> example: base 3.14.12 broke the ca gateway because of an API change.
> Other example: the OMS VME58 driver once dropped one (unused) argument
> from it's configuration function. Everybody had to change their startup
> scripts. These changes usually induce a lot of work in addition to
> simply downloading the new code and compiling it.
> When there are many cross-dependencies like in areaDetector, things are
> getting worse. Suddenly I have to track changes in 5 or more other
> modules (and maybe they require further updates and so on). This costs
> me a lot of my time. This is why I would appreciate to have more
> flexibility in mixing versions and to be able to upgrade only that what
> I really need and want to upgrade.
> By the way, I also appreciate binary compatibility. Up to EPICS base
> 3.14.8 (maybe even up to 3.14.11), large parts of base were binary
> compatible. I could for example upgrade all extensions just by
> upgrading base. 3.14.12 broke this mechanism.
> Some guidelines would help to to keep binary compatibility:
> Do not remove API functions or change their arguments. Do not change
> the meaning (e.g. units) of an argument. Better write additional API
> functions if necessary.
> Do not remove or reorder fields of interface structures. Do not insert
> fields in the middle. Add them at the end. Keep supporting old fields.
> Do not remove shared libraries.
> Also put version macros into your header files if they are used by
> other code. This allows other code to deal with different interfaces.
> It *is* possible to improve software without breaking all existing
> interfaces.
> Or do it like the Linux kernel developers do: Someone who changes an
> interface is responsible for fixing (and testing ?) all drivers that
> use that interface. This of course only works when all drivers are in one
> common repository.
> At the moment I am very hesitant when it comes to upgrades of third
> party drivers because of all the unknown side effects.
What can I say, except: yes, yes, again yes!
Please folks, please pay attention to backwards compatibility.  Mostly it requires just a little attention to the details that Dirk mentions.
One more detail regarding enumerations: when adding values to an enumeration, add them to the *end*, not in the middle, and please *don't* just delete values from the middle of an enumeration list -- if you really want to delete a value then assign explicit (and backwards compatible) values to everything before you delete the offending value.
To be honest I'm speechless to express the frustration I've found in trying to deal with gratuitous changes to interfaces.  *Sometimes* you need to break things.  Sometimes...  Most of the time it's just either inattention or being completely oblivious to the fact that backwards compatibility is a good thing.
So, in summary: please do what Dirk says here!
RE: On compatibility Mark Rivers
"@init handler failed" , "Record initialization failed" and "No reply from device within 1000 ms" 洪春霞
Re: "@init handler failed" , "Record initialization failed" and "No reply from device within 1000 ms" Eric Norum
Re: "@init handler failed" , "Record initialization failed" and "No reply from device within 1000 ms" Dirk Zimoch
Re: "@init handler failed" , "Record initialization failed" and "No reply from device within 1000 ms" Andrew Johnson
Re: "@init handler failed" , "Record initialization failed" and "No reply fro device within 1000 ms" J. Lewis Muir
RE: "@init handler failed" , "Record initialization failed" and "No reply fro device within 1000 ms" Mark Rivers
On compatibility Dirk Zimoch
Prev: On compatibility Dirk Zimoch
Next: RE: CSS-BOY combo boxes Chen, Xihui
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: On compatibility Mark Rivers
