haquin wrote:
I use a CALC record for bitwise operation for exemple : CALC="A & 0x001F"
with a Linux IOC everything is OK,
but with a VxWorks IOC I have the following error: Syntax error, unknown
operator/operand in expression "(A & 0x001F)"
It seems that the 0x001F is not supported, right ?
Yes.
could it be changed ?
Yes.
regards.
That happens because strtod() accepts hex numbers in Linux but not in
vxWorks.
Linux:
man strtod:
"The expected form of the (initial portion of the) string is optional
leading white space as recognized by isspace(3), an optional plus
(‘‘+’’) or minus sign (‘‘-’’) and then either (i) a decimal number, or
(ii) a hexadecimal number, or (iii) an infinity, or (iv) a NAN (not-a-
number)."
vxWorks 5.5 strtod documentation:
"The expected form of the subject sequence is an optional plus or minus
decimal-point character, then an optional exponent part but no floating
suffix. The subject sequence is defined as the longest initial
subsequence of the input string, starting with the first non-white-space
character, that is of the expected form. The subject sequence contains
no characters if the input string is empty or consists entirely of white
space, or if the first non-white-space character is other than a sign, a
digit, or a decimal-point character."
I think adding something like this to epicsStrtod should fix the problem:
if (epicsStrnCaseCmp("0x", cp, 2) == 0) {
return (double)strtoul(str, endp, 16);
Dirk
- Re: mask for bitwise operation in CALC record Eric Norum
- mask for bitwise operation in CALC record haquin
a MEDM replacement Mezger Anton Christian
RE: a MEDM replacement Mark Rivers
<2012>
2025
2026
<2012>
2025
2026
