On Jun 5, 2012, at 6:11 AM, Dirk Zimoch wrote: …..
I think adding something like this to epicsStrtod should fix the problem:
if (epicsStrnCaseCmp("0x", cp, 2) == 0) { return (double)strtoul(str, endp, 16); }
The code with that change doesn't completely match the semantics of strtod as presented in the C99 standard, but it's certainly better than the current code. BTW -- does vxWorks still not supply a working strtod? I think that it is the only system that doesn't just define epicsStrtod as strtod.
- Re: mask for bitwise operation in CALC record Andrew Johnson
- mask for bitwise operation in CALC record haquin
- Re: mask for bitwise operation in CALC record Dirk Zimoch
Re: counter of clients for specific PV in IOC Andrew Johnson
<2012>
2025
2026
<2012>
2025
2026
ANJ, 18 Nov 2013 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
