Hi Eric,
On Jun 5, 2012, at 6:11 AM, Dirk Zimoch wrote:
> I think adding something like this to epicsStrtod should fix the problem:
> if (epicsStrnCaseCmp("0x", cp, 2) == 0) {
> return (double)strtoul(str, endp, 16);
I'll be using strtol() instead in the 3.15 code, so -0x1 works.
On 2012-06-05 Eric Norum wrote:
> The code with that change doesn't completely match the semantics of strtod
> as presented in the C99 standard, but it's certainly better than the
> current code.
What else are we missing? I don't have the C99 standard to look at here.
> BTW -- does vxWorks still not supply a working strtod? I
> think that it is the only system that doesn't just define epicsStrtod as
> strtod.
The wording in the vxWorks 6.8 manpage is exactly the same as Dirk posted from
vxWorks 5.5.
No, we use our version of epicsStrtod() on Windows, Cygwin, vxWorks and
Solaris. I have a branch for 3.15 where I've been working on the numeric
conversions, I'll add some tests for the native strtod().
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
- Re: mask for bitwise operation in CALC record Eric Norum
- mask for bitwise operation in CALC record haquin
- Re: mask for bitwise operation in CALC record Dirk Zimoch
<2012>
2025
2026
<2012>
2025
2026
