1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Problem with EPICS c# Library Version 1.2.0.0
To: [email protected]
Date: Fri, 15 Jun 2012 17:56:11 +0800 (CST)
Hi all,
One problem confused me with the C# EPICS server using C# library Version 1.2.0.0. I tried to set value directly to Record from C# code, then i used caget to get the pv value, i found that the Record value was always 0 even if i have set Record value to 25. But the version before 1.2.0.0is OK! The following is my code and test:
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using PSIEpics;
namespace sharpServer
    class Program
        static void Main(string[] args)
            EpicsServer Server = new EpicsServer();
            //create a new Record which serves a double
            EpicsRecord<double> cpuRecord =Server.GetEpicsRecord<double>("PV:TEST");
            //set HIGH-Alarm
            cpuRecord.HIGH = 50;
            //set HIGH-Alert
            cpuRecord.HIHI = 75;
            //set PV value
            cpuRecord.VAL = 25;
            Console.ReadKey();
[zhangyl@timinglinux2~]$ caget PV:TEST
PV:TEST                         0
Reagards,
Zhang Yuliang
Re: Problem with EPICS c# Library Version 1.2.0.0 Alain Bertrand
RE: Problem with EPICS c# Library Version 1.2.0.0 Bertrand Alain Gregor
Prev: RE: Problems with areaDetector Prosilica driver on Windows? Mark Rivers
Next: Re: Problem with EPICS c# Library Version 1.2.0.0 Alain Bertrand
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: streamdevice: error handling for multiple lines of input from one command Dirk Zimoch
