Updated the download page:
http://gfa-it.web.psi.ch/epicsSharp/index.php?site=download
Will update the documentation in the coming days.
Sincerely,
Alain Bertrand
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of ???
Sent: Friday, June 15, 2012 11:56
To: [email protected]
Subject: Problem with EPICS c# Library Version 1.2.0.0
Hi all,
One problem confused me with the C# EPICS server using C# library Version 1.2.0.0. I tried to set value directly to Record from C# code, then i used caget to get the pv value, i found that the Record value was always 0 even if i have set Record value to 25. But the version before 1.2.0.0is OK! The following is my code and test:
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using PSIEpics;
namespace sharpServer
class Program
static void Main(string[] args)
EpicsServer Server = new EpicsServer();
//create a new Record which serves a double
EpicsRecord<double> cpuRecord =Server.GetEpicsRecord<double>("PV:TEST");
//set HIGH-Alarm
cpuRecord.HIGH = 50;
//set HIGH-Alert
cpuRecord.HIHI = 75;
//set PV value
cpuRecord.VAL = 25;
Console.ReadKey();
[zhangyl@timinglinux2~]$ caget PV:TEST
PV:TEST 0
Reagards,
Zhang Yuliang
- Problem with EPICS c# Library Version 1.2.0.0 张玉亮
Has anyone built SynApps under minGW? S. Stein
subArray problem Steve Hunt
<2012>
2025
2026
Re: Problem with EPICS c# Library Version 1.2.0.0 Alain Bertrand
<2012>
2025
2026
