Folks,
I have found and fixed this problem. It actually affected both Linux and Windows.
The problem arose if MinX + SizeX was greater than MaxSizeX, which is the size of chip. The same is true for Y. This is an invalid geometry, but their library does not return an error status, and silently reduces SizeX. However, it has a subtle bad side-effect; subsequent attempts to change the AcquireTime or AcquirePeriod do not return errors, but they do not take effect until the IOC is rebooted! I have fixed the problem by reducing SizeX or SizeY if the requested region would be larger than the chip.
This will be in release R1-8. It has been committed to Subversion:
https://subversion.xor.aps.anl.gov/synApps/areaDetector/trunk
Meanwhile the problem can be worked around by manually reducing SizeX so that MinX + SizeX <= MaxSizeX. Same for Y.
Cheers,
-----Original Message-----
Sent: Thursday, June 14, 2012 9:12 AM
To: [email protected]
Cc: [email protected]; [email protected]
Subject: RE: Problems with areaDetector Prosilica driver on Windows?
An APS beamline with a new Prosilica system reported this same problem yesterday. They were running areaDetector R1-8beta1 prebuilt for win32-x86 on a Windows XP system.
When I looked at the system it was indeed displaying the behavior I have heard reported elsewhere. Changing AcquireTime and AcquirePeriod did not have any effect, though the readbacks displayed the new value. When restarting the IOC the new values did take effect.
However, I then changed the BinX and BinY, and those changes did take effect immediately. I also changed MinX and MinY to 0. To my surprise, after doing that then everything worked fine! Changing AcquireTime and AcquirePeriod had immediate effect, even without stopping acquisition.
At that point I exited the IOC application and restarted it. Changing AcquireTime and AcquirePeriod still worked normally, the problem seemed to have disappeared!
I can't explain the problem, so I don't know if it's in my software, their library, or their firmware. It is very hard to reproduce, since I don't think I can make that system fail again now.
Yan Fen and Ken, please try this and see if it fixes the problem for you as well.
Cheers,
Sent: Friday, June 08, 2012 7:16 AM
Subject: Problems with areaDetector Prosilica driver on Windows?
Folks,
I have now have 2 reports of problems with the R1-7 areaDetector Prosilica driver on Windows.
The reported problem is that when making any changes to things like the exposure time, exposure period, color mode, etc. the values do not take effect immediately, but only after restarting the IOC.
I cannot reproduce the problem on my systems.
Has anyone else seen such a problem? If so, can you please tell me what OS (XP, Windows 7, 32 or 64 bit, etc.).
- Problems with areaDetector Prosilica driver on Windows? Mark Rivers
- RE: Problems with areaDetector Prosilica driver on Windows? Mark Rivers
Re: thermocouple solutions Wesley Moore
Has anyone built SynApps under minGW? S. Stein
<2012>
2025
2026
EPICS host architectures Benjamin Franksen
<2012>
2025
2026
