Subject: Re: iptables example script for EPICS CA
To: <[email protected]>
Date: Mon, 2 Jul 2012 15:24:51 +0200
On Friday, June 29, 2012, John William Sinclair wrote:
> Here's a previous submission:
> Thanks to input from Jeff Hill, Ralph Lange, and Andrew Johnson I think
> that the following is an accurate description of the firewall settings
> needed to support channel access.
> If you want channel access clients on a machine to be able to see beacons
> and replies to broadcast PV search requests you need to permit inbound
> UDP packets with source port EPICS_CA_SERVER_PORT (default is 5064) or
> destination port EPICS_CA_REPEATER_PORT (default is 5065).  On systems
> using iptables this can be accomplished by rules like
> 	-A INPUT -s 192.168.0.0/22 -p udp --sport 5064 -j ACCEPT
> 	-A INPUT -s 192.168.0.0/22 -p udp --dport 5065 -j ACCEPT
> If you want channel access servers (e.g. "soft IOCs") on a machine to be
> able to see clients you need to permit inbound TCP or UDP packets with
> source port EPICS_CA_SERVER_PORT (default is 5064).  On systems using
> 	-A INPUT -s 192.168.0.0/22 -p udp --dport 5064 -j ACCEPT
> 	-A INPUT -s 192.168.0.0/22 -p tcp --dport 5064 -j ACCEPT
> The above sets of rules are complete assuming that there's no blocking of
> outbound traffic.
> In all cases the "-s 192.168.0.0/22" specifies the range of addresses
> from which you wish to accept packets.
How about adding this text to the CA reference manual (possibly in an
appendix)?
Cheers
Ben
Attachment: signature.asc
Description: This is a digitally signed message part.
Re: iptables example script for EPICS CA Andrew Johnson
RE: iptables example script for EPICS CA Hill, Jeff
iptables example script for EPICS CA Mark Rivers
Re: iptables example script for EPICS CA John William Sinclair
Prev: Re: SynApps build error : win32-x86 Benjamin Franksen
Next: Vxworks NFS issue Chen Xue
Prev: Re: iptables example script for EPICS CA John William Sinclair
Next: Re: iptables example script for EPICS CA Andrew Johnson
