Sounds like a good idea. I created this bug entry.
https://bugs.launchpad.net/epics-base/+bug/1020131
> -----Original Message-----
> From: [email protected] [mailto:[email protected]]
> On Behalf Of Benjamin Franksen
> Sent: Monday, July 02, 2012 7:25 AM
> To: [email protected]
> Subject: Re: iptables example script for EPICS CA
> On Friday, June 29, 2012, John William Sinclair wrote:
> > Here's a previous submission:
> > Thanks to input from Jeff Hill, Ralph Lange, and Andrew Johnson I think
> > that the following is an accurate description of the firewall settings
> > needed to support channel access.
> > If you want channel access clients on a machine to be able to see
> beacons
> > and replies to broadcast PV search requests you need to permit inbound
> > UDP packets with source port EPICS_CA_SERVER_PORT (default is 5064) or
> > destination port EPICS_CA_REPEATER_PORT (default is 5065). On systems
> > using iptables this can be accomplished by rules like
> > -A INPUT -s 192.168.0.0/22 -p udp --sport 5064 -j ACCEPT
> > -A INPUT -s 192.168.0.0/22 -p udp --dport 5065 -j ACCEPT
> > If you want channel access servers (e.g. "soft IOCs") on a machine to be
> > able to see clients you need to permit inbound TCP or UDP packets with
> > source port EPICS_CA_SERVER_PORT (default is 5064). On systems using
> > -A INPUT -s 192.168.0.0/22 -p udp --dport 5064 -j ACCEPT
> > -A INPUT -s 192.168.0.0/22 -p tcp --dport 5064 -j ACCEPT
> > The above sets of rules are complete assuming that there's no blocking
> of
> > outbound traffic.
> > In all cases the "-s 192.168.0.0/22" specifies the range of addresses
> > from which you wish to accept packets.
> How about adding this text to the CA reference manual (possibly in an
> appendix)?
> Cheers
> Ben
- iptables example script for EPICS CA Mark Rivers
- Re: iptables example script for EPICS CA John William Sinclair
- Re: iptables example script for EPICS CA Benjamin Franksen
Re: iptables example script for EPICS CA Andrew Johnson
scan save data problem Chen Xue
<2012>
2025
2026
Vxworks NFS issue Chen Xue
<2012>
2025
2026
