1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS Base version 3.15.0.1 released
To: [email protected]
Date: Fri, 03 Aug 2012 10:14:25 +0200
Hi Andrew et al,
Congratulations on the first EPICS version > Pi release! ;-)
We made an attempt to integrate the new EPICS base into ITER's CODAC
Core System, however we did not get very far because it seems that there
is still quite some work needed to be done to EPICS modules. I haven't
spent a lot of time searching for all the problems but basically I got
stuck with asyn module which fails to compile due to some changes in
eventRecord API (i.e. it tries to assign short integer to char[40] 'val'
field of eventRecord structure).
Either way, we would like to help you with testing of the new EPICS base
because at ITER it is not really required for operation, yet. However,
we will need at least to get all the modules successfully compiled.
This question more applies to module maintainers, but perhaps you
already know the answer. What are the plans with migration of (at least
the more common) EPICS modules to 3.15?
Best Regards,
Anze Zagar.
Re: EPICS Base version 3.15.0.1 released Dirk Zimoch
Re: EPICS Base version 3.15.0.1 released Kevin Peterson
EPICS Base version 3.15.0.1 released Andrew Johnson
Prev: Re: aSub INPA field and CPP attribute on win32-x86 platform Janez Golob
Next: Re: EPICS Base version 3.15.0.1 released Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: EPICS Base version 3.15.0.1 released Andrew Johnson
