I have successfully built the released version of synApps_5_6 against
base 3.15.0.1 on RHEL6 (linux-x86_64-debug). The details of my changes
are attached. Not all of my changes are backwards-compatible.
I had to modify the following files:
asyn-4-18/asyn/asynRecord/asynRecord.dbd
asyn-4-18/asyn/devGpib/devCommonGpib.c
asyn-4-18/asyn/drvAsynSerial/drvAsynIPPort.dbd
asyn-4-18/asyn/drvAsynSerial/drvAsynSerialPort.dbd
asyn-4-18/asyn/gsIP488/drvGsIP488.dbd
asyn-4-18/asyn/linuxGpib/drvLinuxGpib.dbd
asyn-4-18/asyn/ni1014/drvNi1014.dbd
asyn-4-18/asyn/vxi11/drvVxi11.dbd
autosave-4-8/asApp/src/fGetDateStr.c
autosave-4-8/asApp/src/save_restore.c
calc-2-9/calcApp/src/aCalcoutRecord.c
ipac-2-11/tyGSOctal/tyGSOctal.dbd
mca-7-1/mcaApp/mcaSrc/mcaRecord.c
motor-6-7/motorApp/MotorSimSrc/motorSimSupport.dbd
motor-6-7/motorApp/MotorSrc/motorRecord.cc
motor-6-7/motorApp/MotorSrc/motorRecord.dbd
motor-6-7/motorApp/OrielSrc/devEMC18011.cc
motor-6-7/motorApp/PiJenaSrc/devPIJEDS.cc
motor-6-7/motorApp/PiSrc/devPIE516.cc
motor-6-7/motorApp/PiSrc/devPIE710.cc
motor-6-7/motorApp/PiSrc/devPIE816.cc
motor-6-7/motorApp/SoftMotorSrc/devSoft.cc
motor-6-7/motorApp/ThorLabsSrc/devMDT695.cc
seq-2-1-3/configure/RULES_BUILD
sscan-2-7/sscanApp/src/Makefile
sscan-2-7/sscanApp/src/menuSscan.dbd
sscan-2-7/sscanApp/src/recDynLink.c
sscan-2-7/sscanApp/src/recDynLink.h
sscan-2-7/sscanApp/src/saveData.c
sscan-2-7/sscanApp/src/scanparmRecord.dbd
sscan-2-7/sscanApp/src/sscanMenu.dbd
sscan-2-7/sscanApp/src/sscanRecord.c
sscan-2-7/sscanApp/src/sscanRecord.dbd
sscan-2-7/sscanApp/src/sscanSupport.dbd
std-3-1/stdApp/src/devTimeOfDay.c
stream-2-5-1/streamDevice/src/AsynDriverInterface.cc
stream-2-5-1/streamDevice/src/Makefile
stream-2-5-1/streamDevice/src/StreamEpics.cc
stream-2-5-1/streamDevice/srcSynApps/Makefile
stream-2-5-1/streamDevice/streamApp/Makefile
vac-1-4/vacApp/src/devDigitelPump.dbd
vac-1-4/vacApp/src/devVacSen.dbd
xxx-5-6/xxxApp/src/Makefile
xxx-5-6/xxxApp/src/xxxCommonInclude.dbd
Kevin
diff --git a/.gitignore b/.gitignore
index 501c31c..def9913 100644
--- a/.gitignore
+++ b/.gitignore
@@ -9,6 +9,7 @@ html
O.Common
O.linux-x86_64
O.linux-x86_64-debug
+O.solaris-sparc-gnu
envPaths
cdCommands
bnf.inc
diff --git a/asyn-4-18/asyn/asynRecord/asynRecord.dbd b/asyn-4-18/asyn/asynRecord/asynRecord.dbd
index e39dd9e..4fb93ed 100644
--- a/asyn-4-18/asyn/asynRecord/asynRecord.dbd
+++ b/asyn-4-18/asyn/asynRecord/asynRecord.dbd
@@ -122,7 +122,6 @@ recordtype(asyn) {
promptgroup(GUI_INPUTS)
special(SPC_MOD)
interest(1)
- initial("")
size(40)
field(ADDR,DBF_LONG) {
@@ -143,7 +142,6 @@ recordtype(asyn) {
special(SPC_MOD)
interest(2)
- initial("")
size(40)
field(REASON,DBF_LONG) {
diff --git a/asyn-4-18/asyn/devGpib/devCommonGpib.c b/asyn-4-18/asyn/devGpib/devCommonGpib.c
index ad7e19a..b28ac15 100644
--- a/asyn-4-18/asyn/devGpib/devCommonGpib.c
+++ b/asyn-4-18/asyn/devGpib/devCommonGpib.c
@@ -21,6 +21,7 @@
#include <epicsAssert.h>
#include <epicsStdio.h>
+#include <epicsVersion.h>
#include <recGbl.h>
#include <dbAccess.h>
#include <dbScan.h>
@@ -449,7 +450,6 @@ long devGpib_readEv(eventRecord * pev)
static void evFinish(gpibDpvt * pgpibDpvt,int failure)
- unsigned short value;
eventRecord *pev = ((eventRecord *) (pgpibDpvt->precord));
gpibCmd *pgpibCmd = gpibCmdGet(pgpibDpvt);
int cnvrtStat;
@@ -470,9 +470,14 @@ static void evFinish(gpibDpvt * pgpibDpvt,int failure)
"%s no msg buffer\n",pev->name);
failure = -1;
} else {/* interpret msg with predefined format and write into val/rval */
+#if ((EPICS_VERSION<=(3)) && (EPICS_REVISION<=(14)))
+ unsigned short value;
char *format = (pgpibCmd->format) ? (pgpibCmd->format) : "hu";
if (sscanf(pgpibDpvt->msg, format, &value) == 1) {
pev->val = value;
+#else
+ if (sscanf(pgpibDpvt->msg, " %39s", pev->val) == 1) {
+#endif
pev->udf = FALSE;
} else { /* sscanf did not find or assign the parameter */
failure = -1;
diff --git a/asyn-4-18/asyn/drvAsynSerial/drvAsynIPPort.dbd b/asyn-4-18/asyn/drvAsynSerial/drvAsynIPPort.dbd
index 08d0245..e98c2c9 100644
--- a/asyn-4-18/asyn/drvAsynSerial/drvAsynIPPort.dbd
+++ b/asyn-4-18/asyn/drvAsynSerial/drvAsynIPPort.dbd
@@ -1,3 +1,2 @@
registrar(drvAsynIPPortRegisterCommands)
registrar(drvAsynIPServerPortRegisterCommands)
-include "asyn.dbd"
diff --git a/asyn-4-18/asyn/drvAsynSerial/drvAsynSerialPort.dbd b/asyn-4-18/asyn/drvAsynSerial/drvAsynSerialPort.dbd
index a6ebb6a..3379453 100644
--- a/asyn-4-18/asyn/drvAsynSerial/drvAsynSerialPort.dbd
+++ b/asyn-4-18/asyn/drvAsynSerial/drvAsynSerialPort.dbd
@@ -1,2 +1 @@
registrar(drvAsynSerialPortRegisterCommands)
-include "asyn.dbd"
diff --git a/asyn-4-18/asyn/gsIP488/drvGsIP488.dbd b/asyn-4-18/asyn/gsIP488/drvGsIP488.dbd
index 443813e..1f045ac 100644
--- a/asyn-4-18/asyn/gsIP488/drvGsIP488.dbd
+++ b/asyn-4-18/asyn/gsIP488/drvGsIP488.dbd
@@ -1,3 +1,2 @@
registrar(gsIP488RegisterCommands)
variable(gsip488Debug,int)
-include "asyn.dbd"
diff --git a/asyn-4-18/asyn/linuxGpib/drvLinuxGpib.dbd b/asyn-4-18/asyn/linuxGpib/drvLinuxGpib.dbd
index 161600c..db40027 100644
--- a/asyn-4-18/asyn/linuxGpib/drvLinuxGpib.dbd
+++ b/asyn-4-18/asyn/linuxGpib/drvLinuxGpib.dbd
@@ -1,2 +1 @@
registrar(GpibBoardDriverRegister)
-include "asyn.dbd"
diff --git a/asyn-4-18/asyn/ni1014/drvNi1014.dbd b/asyn-4-18/asyn/ni1014/drvNi1014.dbd
index 792b314..1843372 100644
--- a/asyn-4-18/asyn/ni1014/drvNi1014.dbd
+++ b/asyn-4-18/asyn/ni1014/drvNi1014.dbd
@@ -1,2 +1 @@
registrar(ni1014RegisterCommands)
-include "asyn.dbd"
diff --git a/asyn-4-18/asyn/vxi11/drvVxi11.dbd b/asyn-4-18/asyn/vxi11/drvVxi11.dbd
index 4a78b14..a73fb27 100644
--- a/asyn-4-18/asyn/vxi11/drvVxi11.dbd
+++ b/asyn-4-18/asyn/vxi11/drvVxi11.dbd
@@ -1,2 +1 @@
registrar(vxi11RegisterCommands)
-include "asyn.dbd"
diff --git a/autosave-4-8/asApp/src/fGetDateStr.c b/autosave-4-8/asApp/src/fGetDateStr.c
index 147fc80..a5b0c51 100644
--- a/autosave-4-8/asApp/src/fGetDateStr.c
+++ b/autosave-4-8/asApp/src/fGetDateStr.c
@@ -67,19 +67,19 @@ DEVELOPMENT CENTER AT ARGONNE NATIONAL LABORATORY (708-252-2000).
#include <dbCommon.h>
#include <recGbl.h>
#include <devSup.h>
-#include <tsDefs.h>
#include <fGetDateStr.h>
int fGetDateStr( char datetime[])
- TS_STAMP now;
+ epicsTimeStamp now;
char time_text[32];
char tmp[16];
char *p, *p1, *p2;
- tsLocalTime(&now);
- p = tsStampToText( &now, TS_TEXT_MMDDYY, time_text);
+ epicsTimeGetCurrent(&now);
+ /*p = tsStampToText( &now, TS_TEXT_MMDDYY, time_text);*/
+ p = epicsTimeToStrftime(time_text, sizeof(time_text), "%m/%d/%y %H:%M:%S.%09f", &now);
p2 = tmp;
if((p1 = strchr(p, (int) '/'))) {
*p1= 0;
diff --git a/autosave-4-8/asApp/src/save_restore.c b/autosave-4-8/asApp/src/save_restore.c
index d7aaa11..9a4770b 100644
--- a/autosave-4-8/asApp/src/save_restore.c
+++ b/autosave-4-8/asApp/src/save_restore.c
@@ -148,7 +148,6 @@
#include <epicsThread.h>
#include <epicsExport.h>
#include <iocsh.h>
#include <macLib.h>
#include <callback.h>
#include <epicsMutex.h>
diff --git a/calc-2-9/calcApp/src/aCalcoutRecord.c b/calc-2-9/calcApp/src/aCalcoutRecord.c
index 42da0ea..f4c2b4c 100644
--- a/calc-2-9/calcApp/src/aCalcoutRecord.c
+++ b/calc-2-9/calcApp/src/aCalcoutRecord.c
@@ -893,11 +893,11 @@ static void monitor(acalcoutRecord *pcalc)
for (i=0, panew=&pcalc->aa; i<ARRAY_MAX_FIELDS; i++, panew++) {
- if (*panew && (pcalc->new & (1<<i))) {
+ if (*panew && (pcalc->NEW & (1<<i))) {
db_post_events(pcalc, *panew, monitor_mask|DBE_VALUE|DBE_LOG);
- pcalc->new = 0;
+ pcalc->NEW = 0;
/* Check OVAL field */
if (pcalc->povl != pcalc->oval) {
@@ -949,7 +949,7 @@ static int fetch_values(acalcoutRecord *pcalc)
if (!RTN_SUCCESS(status)) return(status);
/* compare new array value with saved value */
for (j=0; j<pcalc->nelm; j++) {
- if (pcalc->paa[j] != (*pavalue)[j]) {pcalc->new |= 1<<i; break;}
+ if (pcalc->paa[j] != (*pavalue)[j]) {pcalc->NEW |= 1<<i; break;}
diff --git a/ipac-2-11/tyGSOctal/tyGSOctal.dbd b/ipac-2-11/tyGSOctal/tyGSOctal.dbd
index 623fda1..3824bdc 100644
--- a/ipac-2-11/tyGSOctal/tyGSOctal.dbd
+++ b/ipac-2-11/tyGSOctal/tyGSOctal.dbd
@@ -1,5 +1,2 @@
-# This driver depends on drvIpac:
-include "drvIpac.dbd"
# It supplies iocsh commands, so needs a registrar:
registrar(tyGSOctalRegistrar)
diff --git a/mca-7-1/mcaApp/mcaSrc/mcaRecord.c b/mca-7-1/mcaApp/mcaSrc/mcaRecord.c
index cb6eb78..8d6832b 100644
--- a/mca-7-1/mcaApp/mcaSrc/mcaRecord.c
+++ b/mca-7-1/mcaApp/mcaSrc/mcaRecord.c
@@ -106,7 +106,7 @@
#include <recSup.h>
#include <recGbl.h>
#include <special.h>
#include <menuYesNo.h>
#define GEN_SIZE_OFFSET
@@ -806,8 +806,7 @@ read_data:
if (!pmca->acqg) {
/* Use TimeStamp to record end of acquisition */
recGblGetTimeStamp(pmca);
- tsStampToText(&pmca->time, TS_TEXT_MONDDYYYY,
- pmca->stim);
+ epicsTimeToStrftime(pmca->stim,32,"%b %d, %Y %H:%M:%S.%09f",&pmca->time);
/* Trim STIM to 25 characters = .001 sec precision */
pmca->stim[25]='\0';
MARK(M_STIM);
diff --git a/motor-6-7/motorApp/MotorSimSrc/motorSimSupport.dbd b/motor-6-7/motorApp/MotorSimSrc/motorSimSupport.dbd
index 3883b98..f6b21fd 100644
--- a/motor-6-7/motorApp/MotorSimSrc/motorSimSupport.dbd
+++ b/motor-6-7/motorApp/MotorSimSrc/motorSimSupport.dbd
@@ -1,4 +1,3 @@
-include "motorRecord.dbd"
device(motor,VME_IO,devMotorSim,"Motor Simulation")
driver(motorSim)
registrar(motorSimRegister)
diff --git a/motor-6-7/motorApp/MotorSrc/motorRecord.cc b/motor-6-7/motorApp/MotorSrc/motorRecord.cc
index 6a17156..66c8be1 100644
--- a/motor-6-7/motorApp/MotorSrc/motorRecord.cc
+++ b/motor-6-7/motorApp/MotorSrc/motorRecord.cc
@@ -169,6 +169,8 @@ HeadURL: $URL: https://subversion.xor.aps.anl.gov/synApps/motor/tags/R6-7
#include <dbEvent.h>
#include <devSup.h>
#include <math.h>
+#include "menuYesNo.h"
+#include "menuOmsl.h"
#include "motorRecord.h"
diff --git a/motor-6-7/motorApp/MotorSrc/motorRecord.dbd b/motor-6-7/motorApp/MotorSrc/motorRecord.dbd
index 27c2d9c..849b352 100644
--- a/motor-6-7/motorApp/MotorSrc/motorRecord.dbd
+++ b/motor-6-7/motorApp/MotorSrc/motorRecord.dbd
@@ -29,8 +29,6 @@
#Modification Log:
-include "menuYesNo.dbd"
menu(motorDIR) {
choice(motorDIR_Pos,"Pos")
choice(motorDIR_Neg,"Neg")
@@ -72,8 +70,6 @@ menu(motorRMOD) {
choice(motorRMOD_G,"Geometric")
-include "menuOmsl.dbd"
recordtype(motor) {
include "dbCommon.dbd"
field(VERS,DBF_FLOAT) {
diff --git a/motor-6-7/motorApp/OrielSrc/devEMC18011.cc b/motor-6-7/motorApp/OrielSrc/devEMC18011.cc
index bd767ad..980508e 100644
--- a/motor-6-7/motorApp/OrielSrc/devEMC18011.cc
+++ b/motor-6-7/motorApp/OrielSrc/devEMC18011.cc
@@ -40,6 +40,7 @@ Last Modified: $Date: 2008-03-14 20:19:25 $
#include <string.h>
#include <math.h>
#include "motor.h"
#include "motordevCom.h"
diff --git a/motor-6-7/motorApp/PiJenaSrc/devPIJEDS.cc b/motor-6-7/motorApp/PiJenaSrc/devPIJEDS.cc
index c3f79a9..0f19698 100644
--- a/motor-6-7/motorApp/PiJenaSrc/devPIJEDS.cc
+++ b/motor-6-7/motorApp/PiJenaSrc/devPIJEDS.cc
@@ -40,6 +40,7 @@ Last Modified: $Date: 2008-03-14 20:20:03 $
#include <string.h>
#include "motor.h"
diff --git a/motor-6-7/motorApp/PiSrc/devPIE516.cc b/motor-6-7/motorApp/PiSrc/devPIE516.cc
index e70afd9..54b07a1 100644
--- a/motor-6-7/motorApp/PiSrc/devPIE516.cc
+++ b/motor-6-7/motorApp/PiSrc/devPIE516.cc
@@ -41,6 +41,7 @@ Last Modified: $Date: 2008-03-14 20:21:37 $
#include <string.h>
#include "motor.h"
diff --git a/motor-6-7/motorApp/PiSrc/devPIE710.cc b/motor-6-7/motorApp/PiSrc/devPIE710.cc
index 636eb21..71aeeea 100644
--- a/motor-6-7/motorApp/PiSrc/devPIE710.cc
+++ b/motor-6-7/motorApp/PiSrc/devPIE710.cc
@@ -41,6 +41,7 @@ Last Modified: $Date: 2008-03-14 20:21:36 $
#include <string.h>
#include "motor.h"
diff --git a/motor-6-7/motorApp/PiSrc/devPIE816.cc b/motor-6-7/motorApp/PiSrc/devPIE816.cc
index ff6ca3d..2e1e1d1 100644
--- a/motor-6-7/motorApp/PiSrc/devPIE816.cc
+++ b/motor-6-7/motorApp/PiSrc/devPIE816.cc
@@ -41,6 +41,7 @@ Last Modified: 2007/03/30 20:01:05
#include <string.h>
#include "motor.h"
diff --git a/motor-6-7/motorApp/SoftMotorSrc/devSoft.cc b/motor-6-7/motorApp/SoftMotorSrc/devSoft.cc
index 95b2e30..a12bf0e 100644
--- a/motor-6-7/motorApp/SoftMotorSrc/devSoft.cc
+++ b/motor-6-7/motorApp/SoftMotorSrc/devSoft.cc
@@ -58,6 +58,7 @@ NOTES...
#include <recSup.h>
#include "motor.h"
#include "devSoft.h"
diff --git a/motor-6-7/motorApp/ThorLabsSrc/devMDT695.cc b/motor-6-7/motorApp/ThorLabsSrc/devMDT695.cc
index c46b339..d5025d3 100644
--- a/motor-6-7/motorApp/ThorLabsSrc/devMDT695.cc
+++ b/motor-6-7/motorApp/ThorLabsSrc/devMDT695.cc
@@ -41,6 +41,7 @@ Last Modified: $Date: 2008-03-14 20:23:45 $
#include <string.h>
#include <math.h>
#include "motor.h"
diff --git a/seq-2-1-3/configure/RULES_BUILD b/seq-2-1-3/configure/RULES_BUILD
index c2f1bac..61477b5 100644
--- a/seq-2-1-3/configure/RULES_BUILD
+++ b/seq-2-1-3/configure/RULES_BUILD
@@ -68,6 +68,6 @@ endif
$(SNC) $(TARGET_SNCFLAGS) $(SNCFLAGS) $(USR_SNCFLAGS) $(call PATH_FILTER,$<) -o $(@F).tmp
$(MV) $(@F).tmp $@
-clean::
+clean:
@$(RM) $(SNC_CSRC_FILES)
diff --git a/sscan-2-7/sscanApp/src/Makefile b/sscan-2-7/sscanApp/src/Makefile
index eb7f393..45c7722 100644
--- a/sscan-2-7/sscanApp/src/Makefile
+++ b/sscan-2-7/sscanApp/src/Makefile
@@ -21,11 +21,11 @@ Com_DIR = $(EPICS_BASE_LIB)
DBDINC += scanparmRecord
DBDINC += sscanRecord
+DBDINC += menuSscan
# <name>.dbd will be created from <name>Include.dbd
DBD += sscan.dbd
DBD += sscanSupport.dbd
-DBD += sscanMenu.dbd
INC += recDynLink.h
diff --git a/sscan-2-7/sscanApp/src/menuSscan.dbd b/sscan-2-7/sscanApp/src/menuSscan.dbd
new file mode 100644
index 0000000..e97cff8
--- /dev/null
+++ b/sscan-2-7/sscanApp/src/menuSscan.dbd
@@ -0,0 +1,95 @@
+menu(sscanNOYES) {
+ choice(sscanNOYES_NO,"NO")
+ choice(sscanNOYES_YES,"YES")
+menu(sscanDSTATE) {
+ choice(sscanDSTATE_UNPACKED, "UNPACKED")
+ choice(sscanDSTATE_TRIG_ARRAY_READ, "TRIG_ARRAY_READ")
+ choice(sscanDSTATE_ARRAY_READ_WAIT, "ARRAY_READ_WAIT")
+ choice(sscanDSTATE_ARRAY_GET_CALLBACK_WAIT, "ARRAY_GET_CALLBACK_WAIT")
+ choice(sscanDSTATE_RECORD_ARRAY_DATA, "RECORD_ARRAY_DATA")
+ choice(sscanDSTATE_SAVE_DATA_WAIT, "SAVE_DATA_WAIT")
+ choice(sscanDSTATE_PACKED, "PACKED")
+ choice(sscanDSTATE_POSTED, "POSTED")
+menu(sscanLINKWAIT) {
+ choice(sscanLINKWAIT_YES,"Wait")
+ choice(sscanLINKWAIT_NO,"NoWait")
+menu(sscanP1SM) {
+ choice(sscanP1SM_Linear,"LINEAR")
+ choice(sscanP1SM_Table,"TABLE")
+ choice(sscanP1SM_On_The_Fly,"FLY")
+menu(sscanFPTS) {
+ choice(sscanFPTS_No,"NO")
+ choice(sscanFPTS_Freeze,"FREEZE")
+menu(sscanFFO) {
+ choice(sscanFFO_Use_F_Flags,"USE F-FLAGS")
+ choice(sscanFFO_Override,"OVERRIDE")
+menu(sscanPASM) {
+ choice(sscanPASM_Stay,"STAY")
+ choice(sscanPASM_Start_Pos,"START POS")
+ choice(sscanPASM_Prior_Pos,"PRIOR POS")
+ choice(sscanPASM_Peak_Pos,"PEAK POS")
+ choice(sscanPASM_Valley_Pos,"VALLEY POS")
+ choice(sscanPASM_RisingEdge_Pos,"+EDGE POS")
+ choice(sscanPASM_FallingEdge_Pos,"-EDGE POS")
+ choice(sscanPASM_COM,"CNTR OF MASS")
+menu(sscanP1AR) {
+ choice(sscanP1AR_Absolute,"ABSOLUTE")
+ choice(sscanP1AR_Relative,"RELATIVE")
+menu(sscanP1NV) {
+ choice(sscanP1NV_PV_OK,"PV OK")
+ choice(sscanP1NV_No_PV,"No PV")
+ choice(sscanP1NV_PV_NoRead,"PV NoRead")
+ choice(sscanP1NV_PV_xxx,"PV illegal1")
+ choice(sscanP1NV_PV_NoWrite,"PV NoWrite")
+ choice(sscanP1NV_PV_yyy,"PV illegal2")
+ choice(sscanP1NV_PV_NC,"PV BAD")
+menu(sscanPAUS) {
+ choice(sscanPAUS_Go,"GO")
+ choice(sscanPAUS_Pause,"PAUSE")
+menu(sscanFAZE) {
+ choice(sscanFAZE_IDLE,"IDLE")
+ choice(sscanFAZE_INIT_SCAN,"INIT_SCAN")
+ choice(sscanFAZE_BEFORE_SCAN,"DO:BEFORE_SCAN")
+ choice(sscanFAZE_BEFORE_SCAN_WAIT,"WAIT:BEFORE_SCAN")
+ choice(sscanFAZE_MOVE_MOTORS,"MOVE_MOTORS")
+ choice(sscanFAZE_CHECK_MOTORS,"WAIT:MOTORS")
+ choice(sscanFAZE_TRIG_DETCTRS,"TRIG_DETCTRS")
+ choice(sscanFAZE_READ_DETCTRS,"WAIT:DETCTRS")
+ choice(sscanFAZE_RETRACE_MOVE,"RETRACE_MOVE")
+ choice(sscanFAZE_RETRACE_WAIT,"WAIT:RETRACE")
+ choice(sscanFAZE_AFTER_SCAN_DO,"DO:AFTER_SCAN")
+ choice(sscanFAZE_AFTER_SCAN_WAIT,"WAIT:AFTER_SCAN")
+ choice(sscanFAZE_SCAN_DONE,"SCAN_DONE")
+ choice(sscanFAZE_SCAN_PENDING,"SCAN_PENDING")
+ choice(sscanFAZE_PREVIEW,"PREVIEW")
+ choice(sscanFAZE_RECORD_SCALAR_DATA,"RECORD SCALAR DATA")
+menu(sscanACQM) {
+ choice(sscanACQM_NORMAL,"NORMAL")
+ choice(sscanACQM_ACC,"ACCUMULATE")
+ choice(sscanACQM_ADD,"ADD TO PREV")
+menu(sscanACQT) {
+ choice(sscanACQT_SCALAR,"SCALAR")
+ choice(sscanACQT_1D_ARRAY,"1D ARRAY")
+menu(sscanCMND) {
+ choice(sscanCMND_CLEAR_MSG,"Clear msg")
+ choice(sscanCMND_CHECK_LIMITS,"Check limits")
+ choice(sscanCMND_PREVIEW_SCAN,"Preview scan")
+ choice(sscanCMND_CLEAR_ALL_PVS,"Clear all PV's")
+ choice(sscanCMND_CLEAR_POS_PVS_ETC,"Clear pos PV's, etc")
+ choice(sscanCMND_CLEAR_POS_PVS,"Clear pos PV's")
+ choice(sscanCMND_CLEAR_POS_RDBK_PVS_ETC,"Clear pos&rdbk PV's, etc")
+ choice(sscanCMND_CLEAR_POS_RDBK_PVS,"Clear pos&rdbk PV's")
diff --git a/sscan-2-7/sscanApp/src/recDynLink.c b/sscan-2-7/sscanApp/src/recDynLink.c
index 50e8045..9f2db3a 100644
--- a/sscan-2-7/sscanApp/src/recDynLink.c
+++ b/sscan-2-7/sscanApp/src/recDynLink.c
@@ -40,13 +40,13 @@ of this distribution.
#include <taskwd.h>
#include <dbDefs.h>
+#include <dbAddr.h>
#include <epicsPrint.h>
#include <db_access.h>
#include <db_access_routines.h>
#include <cadef.h>
#include <caerr.h>
#include <caeventmask.h>
#include <errlog.h>
#include <epicsExit.h>
@@ -177,7 +177,7 @@ long epicsShareAPI recDynLinkAddInput(recDynLink *precDynLink,char *pvname,
printf("recDynLinkAddInput: pvname is blank\n");
return(-1);
- if (options&rdlDBONLY && db_name_to_addr(pvname,&dbaddr)) return(-1);
+ if (options&rdlDBONLY && dbNameToAddr(pvname,&dbaddr)) return(-1);
if (!inpTaskId) recDynLinkStartTasks();
if (precDynLink->pdynLinkPvt) {
if (recDynLinkDebug > 10)
@@ -230,7 +230,7 @@ long epicsShareAPI recDynLinkAddOutput(recDynLink *precDynLink,char *pvname,
printf("recDynLinkAddOutput: pvname is empty\n");
return(-1);
if (!outTaskId) recDynLinkStartTasks();
diff --git a/sscan-2-7/sscanApp/src/recDynLink.h b/sscan-2-7/sscanApp/src/recDynLink.h
index 2747cdc..69e8655 100644
--- a/sscan-2-7/sscanApp/src/recDynLink.h
+++ b/sscan-2-7/sscanApp/src/recDynLink.h
@@ -12,7 +12,9 @@ of this distribution.
#ifndef INCrecDynLinkh
#define INCrecDynLinkh
+#include <epicsTime.h>
+#include <shareLib.h>
typedef struct recDynLink{
void *puserPvt;
void *pdynLinkPvt;
diff --git a/sscan-2-7/sscanApp/src/saveData.c b/sscan-2-7/sscanApp/src/saveData.c
index 4c6ebb6..52e43fe 100644
--- a/sscan-2-7/sscanApp/src/saveData.c
+++ b/sscan-2-7/sscanApp/src/saveData.c
@@ -187,7 +187,6 @@ extern STATUS nfsUnmount(char *localName);
#include <cadef.h>
#include <epicsMessageQueue.h>
diff --git a/sscan-2-7/sscanApp/src/scanparmRecord.dbd b/sscan-2-7/sscanApp/src/scanparmRecord.dbd
index ef5a5e2..ba447e1 100644
--- a/sscan-2-7/sscanApp/src/scanparmRecord.dbd
+++ b/sscan-2-7/sscanApp/src/scanparmRecord.dbd
@@ -1,4 +1,3 @@
-include "sscanMenu.dbd"
recordtype(scanparm) {
diff --git a/sscan-2-7/sscanApp/src/sscanMenu.dbd b/sscan-2-7/sscanApp/src/sscanMenu.dbd
deleted file mode 100644
index e97cff8..0000000
--- a/sscan-2-7/sscanApp/src/sscanMenu.dbd
+++ /dev/null
@@ -1,95 +0,0 @@
-menu(sscanNOYES) {
- choice(sscanNOYES_NO,"NO")
- choice(sscanNOYES_YES,"YES")
-menu(sscanDSTATE) {
- choice(sscanDSTATE_UNPACKED, "UNPACKED")
- choice(sscanDSTATE_TRIG_ARRAY_READ, "TRIG_ARRAY_READ")
- choice(sscanDSTATE_ARRAY_READ_WAIT, "ARRAY_READ_WAIT")
- choice(sscanDSTATE_ARRAY_GET_CALLBACK_WAIT, "ARRAY_GET_CALLBACK_WAIT")
- choice(sscanDSTATE_RECORD_ARRAY_DATA, "RECORD_ARRAY_DATA")
- choice(sscanDSTATE_SAVE_DATA_WAIT, "SAVE_DATA_WAIT")
- choice(sscanDSTATE_PACKED, "PACKED")
- choice(sscanDSTATE_POSTED, "POSTED")
-menu(sscanLINKWAIT) {
- choice(sscanLINKWAIT_YES,"Wait")
- choice(sscanLINKWAIT_NO,"NoWait")
-menu(sscanP1SM) {
- choice(sscanP1SM_Linear,"LINEAR")
- choice(sscanP1SM_Table,"TABLE")
- choice(sscanP1SM_On_The_Fly,"FLY")
-menu(sscanFPTS) {
- choice(sscanFPTS_No,"NO")
- choice(sscanFPTS_Freeze,"FREEZE")
-menu(sscanFFO) {
- choice(sscanFFO_Use_F_Flags,"USE F-FLAGS")
- choice(sscanFFO_Override,"OVERRIDE")
-menu(sscanPASM) {
- choice(sscanPASM_Stay,"STAY")
- choice(sscanPASM_Start_Pos,"START POS")
- choice(sscanPASM_Prior_Pos,"PRIOR POS")
- choice(sscanPASM_Peak_Pos,"PEAK POS")
- choice(sscanPASM_Valley_Pos,"VALLEY POS")
- choice(sscanPASM_RisingEdge_Pos,"+EDGE POS")
- choice(sscanPASM_FallingEdge_Pos,"-EDGE POS")
- choice(sscanPASM_COM,"CNTR OF MASS")
-menu(sscanP1AR) {
- choice(sscanP1AR_Absolute,"ABSOLUTE")
- choice(sscanP1AR_Relative,"RELATIVE")
-menu(sscanP1NV) {
- choice(sscanP1NV_PV_OK,"PV OK")
- choice(sscanP1NV_No_PV,"No PV")
- choice(sscanP1NV_PV_NoRead,"PV NoRead")
- choice(sscanP1NV_PV_xxx,"PV illegal1")
- choice(sscanP1NV_PV_NoWrite,"PV NoWrite")
- choice(sscanP1NV_PV_yyy,"PV illegal2")
- choice(sscanP1NV_PV_NC,"PV BAD")
-menu(sscanPAUS) {
- choice(sscanPAUS_Go,"GO")
- choice(sscanPAUS_Pause,"PAUSE")
-menu(sscanFAZE) {
- choice(sscanFAZE_IDLE,"IDLE")
- choice(sscanFAZE_INIT_SCAN,"INIT_SCAN")
- choice(sscanFAZE_BEFORE_SCAN,"DO:BEFORE_SCAN")
- choice(sscanFAZE_BEFORE_SCAN_WAIT,"WAIT:BEFORE_SCAN")
- choice(sscanFAZE_MOVE_MOTORS,"MOVE_MOTORS")
- choice(sscanFAZE_CHECK_MOTORS,"WAIT:MOTORS")
- choice(sscanFAZE_TRIG_DETCTRS,"TRIG_DETCTRS")
- choice(sscanFAZE_READ_DETCTRS,"WAIT:DETCTRS")
- choice(sscanFAZE_RETRACE_MOVE,"RETRACE_MOVE")
- choice(sscanFAZE_RETRACE_WAIT,"WAIT:RETRACE")
- choice(sscanFAZE_AFTER_SCAN_DO,"DO:AFTER_SCAN")
- choice(sscanFAZE_AFTER_SCAN_WAIT,"WAIT:AFTER_SCAN")
- choice(sscanFAZE_SCAN_DONE,"SCAN_DONE")
- choice(sscanFAZE_SCAN_PENDING,"SCAN_PENDING")
- choice(sscanFAZE_PREVIEW,"PREVIEW")
- choice(sscanFAZE_RECORD_SCALAR_DATA,"RECORD SCALAR DATA")
-menu(sscanACQM) {
- choice(sscanACQM_NORMAL,"NORMAL")
- choice(sscanACQM_ACC,"ACCUMULATE")
- choice(sscanACQM_ADD,"ADD TO PREV")
-menu(sscanACQT) {
- choice(sscanACQT_SCALAR,"SCALAR")
- choice(sscanACQT_1D_ARRAY,"1D ARRAY")
-menu(sscanCMND) {
- choice(sscanCMND_CLEAR_MSG,"Clear msg")
- choice(sscanCMND_CHECK_LIMITS,"Check limits")
- choice(sscanCMND_PREVIEW_SCAN,"Preview scan")
- choice(sscanCMND_CLEAR_ALL_PVS,"Clear all PV's")
- choice(sscanCMND_CLEAR_POS_PVS_ETC,"Clear pos PV's, etc")
- choice(sscanCMND_CLEAR_POS_PVS,"Clear pos PV's")
- choice(sscanCMND_CLEAR_POS_RDBK_PVS_ETC,"Clear pos&rdbk PV's, etc")
- choice(sscanCMND_CLEAR_POS_RDBK_PVS,"Clear pos&rdbk PV's")
diff --git a/sscan-2-7/sscanApp/src/sscanRecord.c b/sscan-2-7/sscanApp/src/sscanRecord.c
index dc655af..145575f 100644
--- a/sscan-2-7/sscanApp/src/sscanRecord.c
+++ b/sscan-2-7/sscanApp/src/sscanRecord.c
@@ -328,6 +328,7 @@
#include "recDynLink.h"
#include "epicsExport.h"
+#include "menuSscan.h"
#include "sscanRecord.h"
diff --git a/sscan-2-7/sscanApp/src/sscanRecord.dbd b/sscan-2-7/sscanApp/src/sscanRecord.dbd
index c997b55..e44b773 100644
--- a/sscan-2-7/sscanApp/src/sscanRecord.dbd
+++ b/sscan-2-7/sscanApp/src/sscanRecord.dbd
@@ -1,4 +1,3 @@
recordtype(sscan) {
field(VERS,DBF_DOUBLE) {
diff --git a/sscan-2-7/sscanApp/src/sscanSupport.dbd b/sscan-2-7/sscanApp/src/sscanSupport.dbd
index 8bdb44d..db44d4d 100644
--- a/sscan-2-7/sscanApp/src/sscanSupport.dbd
+++ b/sscan-2-7/sscanApp/src/sscanSupport.dbd
@@ -3,6 +3,7 @@
include "scanparmRecord.dbd"
include "sscanRecord.dbd"
+include "menuSscan.dbd"
# DEVICE SUPPORT
diff --git a/std-3-1/stdApp/src/devTimeOfDay.c b/std-3-1/stdApp/src/devTimeOfDay.c
index ad60134..3199302 100644
--- a/std-3-1/stdApp/src/devTimeOfDay.c
+++ b/std-3-1/stdApp/src/devTimeOfDay.c
@@ -62,7 +62,6 @@
#include "dbCommon.h"
#include "stringinRecord.h"
#include "aiRecord.h"
-#include "tsDefs.h"
#include "epicsEvent.h"
#include "epicsSignal.h"
#include "epicsString.h"
@@ -121,10 +120,12 @@ static long createString(psi)
recGblGetTimeStamp(psi); /* get time stamp NOW */
if(psi->phas) {
- tsStampToText(&psi->time, TS_TEXT_MMDDYY, psi->val);
+ /*OLD tsStampToText(&psi->time, TS_TEXT_MMDDYY, psi->val);*/
+ epicsTimeToStrftime(psi->val, 28, "%m/%d/%y %H:%M:%S.%09f", &psi->time);
else {
- tsStampToText(&psi->time, TS_TEXT_MONDDYYYY, psi->val);
+ /*OLD tsStampToText(&psi->time, TS_TEXT_MONDDYYYY, psi->val);*/
+ epicsTimeToStrftime(psi->val, 32, "%b %d, %Y %H:%M:%S.%09f", &psi->time);
/* truncate string to seconds */
diff --git a/stream-2-5-1/streamDevice/src/AsynDriverInterface.cc b/stream-2-5-1/streamDevice/src/AsynDriverInterface.cc
index 26883ea..62a3642 100644
--- a/stream-2-5-1/streamDevice/src/AsynDriverInterface.cc
+++ b/stream-2-5-1/streamDevice/src/AsynDriverInterface.cc
@@ -22,18 +22,9 @@
#include "StreamError.h"
#include "StreamBuffer.h"
-#ifdef EPICS_3_14
#include <epicsTimer.h>
-#else
-#include <assert.h>
-#include <wdLib.h>
-#include <sysLib.h>
-extern "C" {
-#include <callback.h>
-#endif
#include <asynDriver.h>
#include <asynOctet.h>
@@ -134,9 +125,7 @@ static const char* eomReasonStr[] = {
class AsynDriverInterface : StreamBusInterface
-#ifdef EPICS_3_14
, epicsTimerNotify
-#endif
asynUser* pasynUser;
asynCommon* pasynCommon;
@@ -164,13 +153,8 @@ class AsynDriverInterface : StreamBusInterface
const char* outputBuffer;
size_t outputSize;
int peeksize;
-#ifdef EPICS_3_14
epicsTimerQueueActive* timerQueue;
epicsTimer* timer;
-#else
- WDOG_ID timer;
- CALLBACK timeoutCallback;
-#endif
AsynDriverInterface(Client* client);
~AsynDriverInterface();
@@ -189,12 +173,8 @@ class AsynDriverInterface : StreamBusInterface
bool disconnectRequest();
void finish();
-#ifdef EPICS_3_14
// epicsTimerNotify methods
epicsTimerNotify::expireStatus expire(const epicsTime &);
-#else
- static void expire(CALLBACK *pcallback);
-#endif
// local methods
void timerExpired();
@@ -211,21 +191,10 @@ class AsynDriverInterface : StreamBusInterface
(StreamBusInterface::priority());
void startTimer(double timeout) {
-#ifdef EPICS_3_14
timer->start(*this, timeout);
-#else
- callbackSetPriority(priority(), &timeoutCallback);
- wdStart(timer, (int)((timeout+1)*sysClkRateGet())-1,
- reinterpret_cast<FUNCPTR>(callbackRequest),
- reinterpret_cast<int>(&timeoutCallback));
-#endif
void cancelTimer() {
-#ifdef EPICS_3_14
timer->cancel();
-#else
- wdCancel(timer);
-#endif
// asynUser callback functions
@@ -263,16 +232,10 @@ AsynDriverInterface(Client* client) : StreamBusInterface(client)
handleTimeout);
assert(pasynUser);
pasynUser->userPvt = this;
-#ifdef EPICS_3_14
timerQueue = &epicsTimerQueueActive::allocate(true);
assert(timerQueue);
timer = &timerQueue->createTimer();
assert(timer);
-#else
- timer = wdCreate();
- callbackSetCallback(expire, &timeoutCallback);
- callbackSetUser(this, &timeoutCallback);
-#endif
AsynDriverInterface::
@@ -306,12 +269,8 @@ AsynDriverInterface::
// Now, no handler is running any more and none will start.
-#ifdef EPICS_3_14
timer->destroy();
timerQueue->release();
-#else
- wdDelete(timer);
-#endif
pasynManager->disconnect(pasynUser);
pasynManager->freeAsynUser(pasynUser);
pasynUser = NULL;
@@ -1273,22 +1232,12 @@ timerExpired()
-#ifdef EPICS_3_14
epicsTimerNotify::expireStatus AsynDriverInterface::
timerExpired();
return noRestart;
-#else
-void AsynDriverInterface::
-expire(CALLBACK *pcallback)
- AsynDriverInterface* interface =
- static_cast<AsynDriverInterface*>(pcallback->user);
- interface->timerExpired();
-#endif
bool AsynDriverInterface::
connectRequest(unsigned long connecttimeout_ms)
diff --git a/stream-2-5-1/streamDevice/src/Makefile b/stream-2-5-1/streamDevice/src/Makefile
index 99d83b1..8d729a7 100644
--- a/stream-2-5-1/streamDevice/src/Makefile
+++ b/stream-2-5-1/streamDevice/src/Makefile
@@ -36,7 +36,7 @@ include $(TOP)/configure/CONFIG
LIBRARY_DEFAULT = stream
-DBD += $(LIBRARY_DEFAULT).dbd
+#!DBD += $(LIBRARY_DEFAULT).dbd
ifdef ASYN
LIB_LIBS += asyn
diff --git a/stream-2-5-1/streamDevice/src/StreamEpics.cc b/stream-2-5-1/streamDevice/src/StreamEpics.cc
index deb5a61..5626a7b 100644
--- a/stream-2-5-1/streamDevice/src/StreamEpics.cc
+++ b/stream-2-5-1/streamDevice/src/StreamEpics.cc
@@ -22,10 +22,6 @@
#include "devStream.h"
-#ifndef EPICS_3_14
-extern "C" {
-#endif
#include <ctype.h>
#include <stdarg.h>
#include <stdlib.h>
@@ -37,18 +33,6 @@ extern "C" {
#include <alarm.h>
-#ifndef EPICS_3_14
-#include <semLib.h>
-#include <wdLib.h>
-#include <taskLib.h>
-extern DBBASE *pdbbase;
-} // extern "C"
-#else
#include <epicsEvent.h>
@@ -68,8 +52,6 @@ epicsShareFunc int epicsShareAPI iocshCmd(const char *command);
-#endif
#if defined(__vxworks) || defined(vxWorks)
#include <symLib.h>
#include <sysSymTbl.h>
@@ -87,25 +69,16 @@ extern "C" void streamRecordProcessCallback(CALLBACK *pcallback);
extern "C" long streamReload(char* recordname);
class Stream : protected StreamCore
-#ifdef EPICS_3_14
, epicsTimerNotify
-#endif
dbCommon* record;
struct link *ioLink;
streamIoFunction readData;
streamIoFunction writeData;
-#ifdef EPICS_3_14
epicsTimer* timer;
epicsMutex mutex;
epicsEvent initDone;
-#else
- WDOG_ID timer;
- SEM_ID mutex;
- SEM_ID initDone;
-#endif
StreamBuffer fieldBuffer;
int status;
int convert;
@@ -114,13 +87,8 @@ class Stream : protected StreamCore
CALLBACK commandCallback;
CALLBACK processCallback;
-#ifdef EPICS_3_14
expireStatus expire(const epicsTime&);
-#else
-#endif
// StreamCore methods
void protocolStartHook();
@@ -166,11 +134,9 @@ public:
// shell functions ///////////////////////////////////////////////////////
-#ifdef EPICS_3_14
extern "C" {
epicsExportAddress(int, streamDebug);
-#endif
// for subroutine record
extern "C" long streamReloadSub()
@@ -225,7 +191,6 @@ extern "C" long streamReload(char* recordname)
return OK;
-#ifdef EPICS_3_14
static const iocshArg streamReloadArg0 =
{ "recordname", iocshArgString };
static const iocshArg * const streamReloadArgs[] =
@@ -251,7 +216,6 @@ static void streamRegistrar ()
extern "C" {
epicsExportRegistrar(streamRegistrar);
-#endif // EPICS_3_14
// driver support ////////////////////////////////////////////////////////
@@ -265,7 +229,6 @@ struct stream_drvsup {
Stream::drvInit
-#ifdef EPICS_3_14
extern "C" {
epicsExportAddress(drvet, stream);
@@ -277,22 +240,6 @@ void streamEpicsPrintTimestamp(char* buffer, int size)
tlen = tm.strftime(buffer, size, "%Y/%m/%d %H:%M:%S.%03f");
sprintf(buffer+tlen, " %.*s", size-tlen-2, epicsThreadGetNameSelf());
-#else
-void streamEpicsPrintTimestamp(char* buffer, int size)
- int tlen;
- char* c;
- TS_STAMP tm;
- tsLocalTime (&tm);
- tsStampToText(&tm, TS_TEXT_MMDDYY, buffer);
- c = strchr(buffer,'.');
- if (c) {
- c[4] = 0;
- tlen = strlen(buffer);
- sprintf(buffer+tlen, " %.*s", size-tlen-2, taskName(0));
-#endif
long Stream::
report(int interest)
@@ -500,16 +447,8 @@ Stream(dbCommon* _record, struct link *ioLink,
:record(_record), ioLink(ioLink), readData(readData), writeData(writeData)
streamname = record->name;
-#ifdef EPICS_3_14
-#else
- mutex = semMCreate(SEM_INVERSION_SAFE | SEM_Q_PRIORITY);
- initDone = semBCreate(SEM_Q_FIFO, SEM_EMPTY);
-#endif
callbackSetCallback(streamExecuteCommand, &commandCallback);
callbackSetUser(this, &commandCallback);
callbackSetCallback(streamRecordProcessCallback, &processCallback);
@@ -532,15 +471,10 @@ Stream::
record->dpvt = NULL;
debug("~Stream(%s): dpvt cleared\n", name());
-#ifdef EPICS_3_14
timer->destroy();
debug("~Stream(%s): timer destroyed\n", name());
debug("~Stream(%s): timer queue released\n", name());
-#else
- wdDelete(timer);
- debug("~Stream(%s): watchdog destroyed\n", name());
-#endif
releaseMutex();
@@ -635,11 +569,7 @@ initRecord()
debug("Stream::initRecord %s: waiting for initDone\n",
name());
-#ifdef EPICS_3_14
initDone.wait();
-#else
- semTake(initDone, WAIT_FOREVER);
-#endif
debug("Stream::initRecord %s: initDone\n",
name());
@@ -762,21 +692,12 @@ scan(format_t *format, void* value, size_t maxStringSize)
// epicsTimerNotify virtual method ///////////////////////////////////////
-#ifdef EPICS_3_14
epicsTimerNotify::expireStatus Stream::
timerCallback();
return noRestart;
-#else
-void Stream::
- Stream* pstream = static_cast<Stream*>(pcallback->user);
- pstream->timerCallback();
-#endif
// StreamCore virtual methods ////////////////////////////////////////////
@@ -835,11 +756,7 @@ protocolFinishHook(ProtocolResult result)
if (flags & InitRun)
-#ifdef EPICS_3_14
initDone.signal();
-#else
- semGive(initDone);
-#endif
return;
@@ -891,14 +808,7 @@ startTimer(unsigned long timeout)
debug("Stream::startTimer(stream=%s, timeout=%lu) = %f seconds\n",
name(), timeout, timeout * 0.001);
-#ifdef EPICS_3_14
timer->start(*this, timeout * 0.001);
-#else
- wdStart(timer, (timeout+1)*sysClkRateGet()/1000-1,
-#endif
bool Stream::
@@ -1229,7 +1139,6 @@ matchValue(const StreamFormat& format, const void* fieldaddress)
return true;
-#ifdef EPICS_3_14
// Pass command to iocsh
void streamExecuteCommand(CALLBACK *pcallback)
@@ -1244,24 +1153,6 @@ void streamExecuteCommand(CALLBACK *pcallback)
pstream->execCallback(StreamIoSuccess);
-#else
-// Pass command to vxWorks shell
-extern "C" int execute(const char *cmd);
-void streamExecuteCommand(CALLBACK *pcallback)
- if (execute(pstream->outputLine()) != OK)
- pstream->execCallback(StreamIoFault);
- else
- pstream->execCallback(StreamIoSuccess);
-#endif
bool Stream::
execute()
@@ -1274,19 +1165,11 @@ execute()
void Stream::
lockMutex()
-#ifdef EPICS_3_14
mutex.lock();
-#else
- semTake(mutex, WAIT_FOREVER);
-#endif
void Stream::
releaseMutex()
-#ifdef EPICS_3_14
mutex.unlock();
-#else
- semGive(mutex);
-#endif
diff --git a/stream-2-5-1/streamDevice/srcSynApps/Makefile b/stream-2-5-1/streamDevice/srcSynApps/Makefile
index 4fec9f9..1f62740 100644
--- a/stream-2-5-1/streamDevice/srcSynApps/Makefile
+++ b/stream-2-5-1/streamDevice/srcSynApps/Makefile
@@ -7,8 +7,6 @@ include $(TOP)/configure/CONFIG
LIBRARY_DEFAULT = streamSynApps
ifeq ($(LOADABLE_MODULE),YES)
SRCS += $(LIBRARY_DEFAULT)_registerRecordDeviceDriver.cpp
endif
diff --git a/stream-2-5-1/streamDevice/streamApp/Makefile b/stream-2-5-1/streamDevice/streamApp/Makefile
index 892becb..3b0e137 100644
--- a/stream-2-5-1/streamDevice/streamApp/Makefile
+++ b/stream-2-5-1/streamDevice/streamApp/Makefile
@@ -47,7 +47,7 @@ endif
ifneq ($(words $(CALC) $(SYNAPPS)), 0)
# With synApps scalcout record
streamApp_DBD += calcSupport.dbd
-streamApp_DBD += streamSynApps.dbd
+#!streamApp_DBD += streamSynApps.dbd
PROD_LIBS += calc
# older calc versions require sscan. So does new version if it was built with
# sscan
@@ -55,7 +55,7 @@ PROD_LIBS += sscan
PROD_LIBS_DEFAULT += streamSynApps
endif
-streamApp_DBD += stream.dbd
+#!streamApp_DBD += stream.dbd
ifdef PCRE
LIB_LIBS += pcre
@@ -78,7 +78,7 @@ CPPFLAGS += -DDEBUGFILE=StreamDebug.log
include $(TOP)/configure/RULES
-clean:: myclean
+clean: myclean
myclean:
$(RM) core* StreamDebug.log
diff --git a/vac-1-4/vacApp/src/devDigitelPump.dbd b/vac-1-4/vacApp/src/devDigitelPump.dbd
index 44224eb..4cf1dad 100644
--- a/vac-1-4/vacApp/src/devDigitelPump.dbd
+++ b/vac-1-4/vacApp/src/devDigitelPump.dbd
@@ -1,2 +1 @@
device(digitel, INST_IO, devDigitelPump, "asyn DigitelPump")
-include "asyn.dbd"
diff --git a/vac-1-4/vacApp/src/devVacSen.dbd b/vac-1-4/vacApp/src/devVacSen.dbd
index ccc1de2..8c4a405 100644
--- a/vac-1-4/vacApp/src/devVacSen.dbd
+++ b/vac-1-4/vacApp/src/devVacSen.dbd
@@ -1,2 +1 @@
device(vs, INST_IO, devVacSen, "asyn VacSen")
-include "asyn.dbd"
diff --git a/xxx-5-6/xxxApp/src/Makefile b/xxx-5-6/xxxApp/src/Makefile
index 07d1f5b..f0077ce 100644
--- a/xxx-5-6/xxxApp/src/Makefile
+++ b/xxx-5-6/xxxApp/src/Makefile
@@ -140,9 +140,11 @@ endif
ifneq (,$(findstring linux, $(T_A)))
DBD += iocxxxLinux.dbd
iocxxxLinux_DBD += xxxCommonInclude.dbd
- iocxxxLinux_DBD += ADSupport.dbd NDFileNetCDF.dbd
+ #!iocxxxLinux_DBD += ADSupport.dbd NDFileNetCDF.dbd
+ iocxxxLinux_DBD += ADSupport.dbd
xxx_LIBS_Linux += ADBase NDPlugin netCDF
- iocxxxLinux_DBD += simDetectorSupport.dbd commonDriverSupport.dbd
+ #!iocxxxLinux_DBD += simDetectorSupport.dbd commonDriverSupport.dbd
+ iocxxxLinux_DBD += simDetectorSupport.dbd NDPluginSupport.dbd
xxx_LIBS_Linux += simDetector
# If your host supports libpcap and libnet and you want to build Canberra network
@@ -161,7 +163,7 @@ ifneq (,$(findstring linux, $(T_A)))
endif
ifdef DEVIOCSTATS
- iocxxxLinux_DBD += devIocStats.dbd iocAdmin.dbd
+ iocxxxLinux_DBD += devIocStats.dbd
endif
endif
diff --git a/xxx-5-6/xxxApp/src/xxxCommonInclude.dbd b/xxx-5-6/xxxApp/src/xxxCommonInclude.dbd
index 767f6e3..09c4fda 100644
--- a/xxx-5-6/xxxApp/src/xxxCommonInclude.dbd
+++ b/xxx-5-6/xxxApp/src/xxxCommonInclude.dbd
@@ -56,12 +56,10 @@ include "devSPiiPlus.dbd"
include "devSmartMotorMotor.dbd"
include "devSoftMotor.dbd"
include "devThorLabs.dbd"
include "motorSimSupport.dbd"
# seq
include "devSequencer.dbd"
# stream
-include "stream.dbd"
-include "streamSynApps.dbd"
+#include "streamApp.dbd"
- EPICS Base version 3.15.0.1 released Andrew Johnson
- Re: EPICS Base version 3.15.0.1 released Anze Zagar
Re: Cross-compilation, static build, etc J. Lewis Muir
OPC with binary out records pthomas
<2012>
2025
2026
Re: EPICS Base version 3.15.0.1 released Eric Norum
Re: EPICS Base version 3.15.0.1 released Ron Sluiter
<2012>
2025
2026
