1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS Base version 3.15.0.1 released
To: Dirk Zimoch <[email protected]>
Cc: [email protected]
Date: Fri, 3 Aug 2012 07:31:15 -0700
I submitted a fix for the devGpib problem yesterday.  It was a quick fix so better solutions may exist and a new patch implementing such would be welcomed.
On Aug 3, 2012, at 7:09 AM, Dirk Zimoch wrote:
> Anze Zagar wrote:
>> Hi Andrew et al,
>> Congratulations on the first EPICS version > Pi release! ;-)
>> We made an attempt to integrate the new EPICS base into ITER's CODAC
>> Core System, however we did not get very far because it seems that there
>> is still quite some work needed to be done to EPICS modules. I haven't
>> spent a lot of time searching for all the problems but basically I got
>> stuck with asyn module which fails to compile due to some changes in
>> eventRecord API (i.e. it tries to assign short integer to char[40] 'val'
>> field of eventRecord structure).
> There is some code in the asyn GPIB part that tries to access the val field directly via a pointer and thus assumes a certain data type of this field. The better way would be to use a DBADDR structure which would do all necessary type conversions (like any db link is doing it).
> Maybe next week I have a look into asyn. For the time being, you can simply comment out the devGpib blocks from the asyn Makefiles (provided you do not need davGpib support).
> Dirk
Eric Norum
[email protected]
EPICS Base version 3.15.0.1 released Andrew Johnson
Re: EPICS Base version 3.15.0.1 released Anze Zagar
Re: EPICS Base version 3.15.0.1 released Dirk Zimoch
Prev: Re: EPICS Base version 3.15.0.1 released Dirk Zimoch
Next: Searching Postdoc appointment in particle physics Florian Feldbauer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: EPICS Base version 3.15.0.1 released Kevin Peterson
