Subject: Re: EPICS Base version 3.15.0.1 released
To: Anze Zagar <[email protected]>
Cc: [email protected]
Date: Fri, 03 Aug 2012 16:09:53 +0200
Anze Zagar wrote:
Hi Andrew et al,
Congratulations on the first EPICS version > Pi release! ;-)
We made an attempt to integrate the new EPICS base into ITER's CODAC
Core System, however we did not get very far because it seems that there
is still quite some work needed to be done to EPICS modules. I haven't
spent a lot of time searching for all the problems but basically I got
stuck with asyn module which fails to compile due to some changes in
eventRecord API (i.e. it tries to assign short integer to char[40] 'val'
field of eventRecord structure).
There is some code in the asyn GPIB part that tries to access the val field directly via a pointer and thus assumes a certain data type of this field. The better way would be to use a DBADDR structure which would do all necessary type conversions (like any db link is doing it).
Maybe next week I have a look into asyn. For the time being, you can simply comment out the devGpib blocks from the asyn Makefiles (provided you do not need davGpib support).
Dirk
Re: EPICS Base version 3.15.0.1 released Eric Norum
EPICS Base version 3.15.0.1 released Andrew Johnson
Re: EPICS Base version 3.15.0.1 released Anze Zagar
Prev: Re: EPICS Base version 3.15.0.1 released Anze Zagar
Next: Re: EPICS Base version 3.15.0.1 released Eric Norum
