Subject: Re: Installing MEDM on UBUNTU 10.04 LTS
To: [email protected]
Cc: nalaka samarasinghe <[email protected]>
Date: Thu, 9 Aug 2012 10:40:27 -0500
Hi Nalaka,
On 2012-08-09 nalaka samarasinghe wrote:
> nalaka@nalaka-laptop:~/opt/epics/extensions/src/medm$ make
> ../../configure/CONFIG_EXTENSIONS:8: opt/epics/configure/RELEASE: No such
> file or directory
Make can't find the ~/opt/epics/extensions/configure/RELEASE file that it
needs to tell it where Base is installed.  Where did you get the files in your
~/opt/epics/extensions/configure directory?  There should have been a RELEASE
file in it which you will have to edit to tell the build about to your
installation.
> ../../configure/CONFIG_EXTENSIONS:12: opt/epics/base/configure/CONFIG: No
> such file or directory
> Makefile:14: opt/epics/configure/RULES_DIRS: No such file or directory
> make: *** No rule to make target `opt/epics/configure/RULES_DIRS'.  Stop.
> Please help to figure out what is meant by this and please let me know the
> correct way of installing MEDM
The remaining errors should go away once the RELEASE file is present.
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
Installing MEDM on UBUNTU 10.04 LTS nalaka samarasinghe
Prev: Installing MEDM on UBUNTU 10.04 LTS nalaka samarasinghe
Next: Re: The communication between base3.14.8.2 and base3.13.8 Andrew Johnson
Next: Re: Installing MEDM on UBUNTU 10.04 LTS Andrew Johnson
