Subject: Re: The communication between base3.14.8.2 and base3.13.8
To: [email protected]
Cc: 李芳 <[email protected]>
Date: Thu, 9 Aug 2012 10:43:27 -0500
Hi 李芳,
On 2012-08-08 李芳 wrote:
>    My EPICS base is base3.14.8.2, but I want to get access to EPICS
>  base3.13.8 in another computer. For eaxmple using "caget" to get a PV from
>  base3.13.8 in my base3.14.8.2 system. So how do I should.
Those two versions of channel access are compatible, so they should just
connect.  If they don't, that may be because you have a firewall set up in one
or both systems; if that's the case you will need to open up ports 5064 and
5065 for both the UDP and TCP protocols to allow the computers to communicate.
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
The communication between base3.14.8.2 and base3.13.8 李芳
Prev: Re: Installing MEDM on UBUNTU 10.04 LTS Andrew Johnson
Next: Re: Installing MEDM on UBUNTU 10.04 LTS Andrew Johnson
Prev: Re: The communication between base3.14.8.2 and base3.13.8 Zhang Yuliang
Next: Remaining free buffers in an AD plugin queue Emma Shepherd
