Subject: Re: Installing MEDM on UBUNTU 10.04 LTS
To: nalaka samarasinghe <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Fri, 10 Aug 2012 10:21:20 -0500
Hi Nalaka,
On 2012-08-10 you wrote:
> Dear Andrew,
> Please find the entries in the RELEASE file I am copying here.
> # RELEASE,v 1.4 2004/09/07 19:01:28 jba Exp
> # If you don't want to install into $(TOP) dir then
> # define INSTALL_LOCATION_EXTENSIONS here
> #INSTALL_LOCATION_EXTENSIONS=<fullpathname>
> TOP=/opt/epics
> # Location of external products
> EPICS_BASE=opt/epics/base1
> #EPICS_EXTENSIONS = /usr/local/epics/extensions
> EPICS_EXTENSIONS=/opt/epics/extensions
> OAG_APPS=$(TOP)/../../oag/apps
Your EPICS_BASE path above is missing a leading '/' character, which explains
the symptoms you were reporting.  If you put spaces on both sides of the '='
sign it becomes slightly easier to read and recognize these kinds of mistakes.
> P.S : I am attaching the reference i am using for the build herewith as
> well. Please kindly let me know if MEDM build procedure mentioned is
> correct.
Attachment: PDF version of http://nibot-lab.livejournal.com/91787.html
That looks about right, although I haven't actually tried following his
directions myself.  The version numbers that article mentions are in many
cases a bit out of date now, but the techniques are generally the same.
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
Installing MEDM on UBUNTU 10.04 LTS nalaka samarasinghe
Prev: Re: The communication between base3.14.8.2 and base3.13.8 Andrew Johnson
Next: Re: EPICS Base version 3.15.0.1 released Martin Konrad
Prev: Re: Installing MEDM on UBUNTU 10.04 LTS Andrew Johnson
Next: Member of CLS Controls Group Elder Matias
