Subject: RE: Creating INLINK/OUTLINK in record support
To: <[email protected]>
Date: Fri, 24 Aug 2012 12:02:36 +0200
Hi- I know this isn't quite what you're asking for, since you
already have your huge .dbd file, but perhaps others can use it.
I wrote an awk script some years ago to help me generate dbd's for
records with potentially hundreds of fields whose names were easily
automatically generated, like for example ".[A-D][X][0-9][0-9]",
which would be (4*1*10*10)=400 fields (ie. .AX00, .AX01, .AX02,
..., .BX00, ..., all the way to .DX99).
If I recall correctly, the resulting file could be #include'd
unmodified into a top-level .dbd, but I haven't tried it lately.
See attached.
cheers,
Mike
ps- I second the nomination for SNL when run-time dynamic PV
assignment is desired.
#!/bin/sh
# 2012-08-24 updated comments [[email protected]]
# 2006-01-10 changed "dim" to "for" [[email protected]]
# 2005-04-05 original [[email protected]]
# fxplode -- combinatorial EPICS field generation
# Usage:
#       fxplode inputfile > outfile
# This script accepts input blocks of the form:
#       begin DBF_FLOAT
#       prompt("int_coef")
#       promptgroup(GUICOMMON)
#       pp(TRUE)
#         <... any other arbitrary field specs, e.g. interest(1), &c >
#       for II IQ QI QQ
#       for 0 1 2 3
#       for A B C
#       end
# and outputs EPICS "record field" definitions suitable for inclusion in a
# .dbd file, generating all possible combinations of the (up to 4) nested "for"s.
# The "for" values need not be single characters, but any possible combinations
# must not exceed 4 chars total (EPICS field-name limit).
# Input is processed in blocks, starting with "begin" and ending with "end" lines:
#   lines starting with "begin" reset things, and save the field type
#   lines starting with "for" specify one of up to 4 lists of nested substrings
#   lines starting with "end" starts processing with current specs
#   lines starting with "#" are ignored (and passed through)
#   all other lines are saved and written out unchanged in each output field
#   All input lines are also output as comments (prepended with "# ").
# The example above will output 4*4*3=48 field specs:
#	field(II0A,DBF_FLOAT) {
#		pp(TRUE)
#		interest(1)
#	field(II0B,DBF_FLOAT) { ...
#	field(II0C,DBF_FLOAT) { ...
#	  ... all the way to:
#	field(QQ3B,DBF_FLOAT) { ...
#	field(QQ3C,DBF_FLOAT) { ...
# A comment is added at the end showing how many fields were generated, and if any
# duplicates were found; duplicates are listed without a "#" so they intentionally
# cause run-time load errors.
cat $* | /bin/nawk '
BEGIN {
    print "#================================================"
    print "#=== GENERATED FILE... do not edit!"
    print "#=== fxplode v1.0"
    print "#"
    ntot = 0
{		# count all lines, and output as comments
    lineno++
    print "# " $0
/^#/ {		# skip input comments
    next
{		# process all others
    if ($1 == "begin") {
	type = $2
	for (x = 0; x < 4; x++) {
	    din[x]   = 1
	    dim[x 0] = ""
	x = kex = 0
	next
    if ($1 == "for") {
	din[x] = NF - 1
	for (y = 0; y < NF-1; y++) {
	    dim[x y] = $(y+2)
	if (x++ >= 4) {
	    print "too many \"for\"s (max 4)... line " lineno
	    exit
	next
    if ($1 == "end") {
	splode()
	next
    if (NF > 0) extra[kex++] = $0
END {		# done; check for duplicates
    dup = 0
    for (i = 0; i < ntot; i++) {
	if (num[name[i]] > 1) {
	    print "*** [fxplode] *** duplicate field: " name[i] " (" num[name[i]] " times)"
	    dup++
    print "# " ntot " fields, " dup " duplicates"
function splode()
    for (i0 = 0; i0 < din[0]; i0++) {
    for (i1 = 0; i1 < din[1]; i1++) {
    for (i2 = 0; i2 < din[2]; i2++) {
    for (i3 = 0; i3 < din[3]; i3++) {
	name[ntot] = dim[0 i0] dim[1 i1] dim[2 i2] dim[3 i3]
	num[name[ntot]]++
	if (length(name[ntot]) > 4) {
		print "*** [fxplode] *** field name too long (max 4): " name[ntot]
	else {
		print "\tfield(" name[ntot] "," type ") {"
		for (k = 0; k < kex; k++) printf("\t\t%s\n", extra[k])
		print "\t}"
	ntot++
Re: Creating INLINK/OUTLINK in record support Andrew Johnson
RE: Creating INLINK/OUTLINK in record support Zhang, Dehong
Prev: RE: Creating INLINK/OUTLINK in record support Zhang, Dehong
Next: Re: Creating INLINK/OUTLINK in record support Tim Mooney
