Subject: Re: aiRecord conversion
Cc: [email protected]
Date: Tue, 28 Aug 2012 11:30:00 -0700
The problem is that a google search bypasses that top page -- a google search for 'epics ai record' produces
  1. Chapter 4: ai--Analog Input
    www.aps.anl.gov/epics/EpicsDocumentation/.../RecordRef/Recordref-...
    EPICS Record Reference Manual ... The analog input record has the standard fields for specifying under what circumstances the record will be processed.
  2. EPICS Re: soft device for ai record works as sscanf.
    www.aps.anl.gov/epics/tech-talk/2009/msg00311.php
    Feb 24, 2009 – EPICS Re: soft device for ai record works as sscanf.
  3. EPICS Record Reference Manual
    Record Reference Manual ... EPICS Release 3.13 ... Chapter 3: - Fields Common to Many Record Types · Chapter 4: - ai--Analog Input · Chapter 5: - ao - Analog ...
  4. EPICS Analog Input records, Stream Device, and INVALID Alarms
    www.aps.anl.gov/epics/tech-talk/2010/msg00416.php
    Apr 15, 2010 – I have a database that communicates via RS-232 to a vacuum gauge controller. I do this by setting up an Analog In record, that has the DTYP ...
Clicking on the link provided as the first hit takes you to the ancient page -- with no warning that it's totally out of date.
The safest approach IMHO is to take that old stuff completely off the web server -- or at least add the magic to tell google's crawlers not to index it.
On Aug 28, 2012, at 11:12 AM, Andrew Johnson <[email protected]> wrote:
Hi Eric,
On 2012-08-28 Eric Norum wrote:
Maybe, but the fact that it seems to be showing up as the top google hit is
a matter of concern, I think. Proof by example -- it's clearly already
tripped up one new developer. I really (note, no yelling this time  :-) )
think that the ancient documentation should be expunged.
I have added some text to that title page directing people to the Wiki for
updated versions.
…..snip…...
Eric Norum
[email protected]
Re: aiRecord conversion Andrew Johnson
aiRecord conversion Bruno Seiva Martins
Re: aiRecord conversion Ralph Lange
Re: aiRecord conversion Eric Norum
Prev: Re: aiRecord conversion Andrew Johnson
Next: Re: aiRecord conversion Andrew Johnson
