Subject: Re: Compilation error EPICS for RTEMS
To: Bruno Seiva Martins <[email protected]>
Cc: [email protected]
Date: Tue, 11 Sep 2012 08:17:52 -0700
AFAIK the RTEMS-4.11 stuff is still a development branch.
I just checked and found that I could use EPICS/RTEMS-4.10 on my OS X "Mountain Lion" host as follows:
1) Download and install gmp-5.0.5, mpc-1.0., mpfr-3.1.1, automake-1.11.1and autoconf-2.68 with PREFX=/usr/llocal/rtems/rtems-4.10.
2) Run the getAndBuildTools-4.10.sh script (attached).
3) Downloaded and unpacked rtems-4.10.2.tar.bz2 and rtems-addon-packages-4.10.2.tar.bz2 from http://www.rtems.org/ftp/pub/rtems/4.10.2/
4) Ran the bootstrap script in the top RTEMS source directory.
5) Build RTEMS:
/usr/local/rtems/rtems-4.10/src/rtems-4.10.2/configure --prefix=/usr/local/rtems/rtems-4.10 --enable-cxx --disable-rdbg --enable-tests=samples --enable-networking --enable-posix --target=powerpc-rtems4.10 '--enable-rtemsbsp=mvme3100 mvme2100 beatnik'
make -w
make -w install
6) Build the RTEMS add-on packages (to get readline)
7) Build 'extended BSP' support.
8) Build EPICS with the attached configure/os/CONFIG_SITE.Common.RTEMS
I tried the above with the RTEMS-4.11 stuff but ran into problems at step (7) -- I couldn't get the the 'libbspExt' stuff to build.  I don't think that there's anything wrong with the source, just the Makefile arrangements seem to have changed between 4.10 and 4.11.  It would be nice if the bspExt stuff could migrate to RTEMS itself….
Attachment: getAndBuildTools-4.10.sh
Description: Binary data
Attachment: CONFIG_SITE.Common.RTEMS
On Sep 10, 2012, at 5:16 AM, Bruno Seiva Martins <[email protected]> wrote:
Please ignore the last message, it does not work...
Bruno Seiva Martins
Eric Norum
[email protected]
Re: Compilation error EPICS for RTEMS Joel Sherrill
Compilation error EPICS for RTEMS Bruno Seiva Martins
Re: Compilation error EPICS for RTEMS Bruno Seiva Martins
Prev: Re: camonitor bug for string as array of chars Ralph Lange
Next: Re: ISEG EHS device support on the Raspberry Pi Computer Eric Norum
Prev: Re: Compilation error EPICS for RTEMS Bruno Seiva Martins
Next: Re: Compilation error EPICS for RTEMS Joel Sherrill
