1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Compilation error EPICS for RTEMS
To: Eric Norum <[email protected]>
Date: Tue, 11 Sep 2012 10:31:34 -0500
Why doesn't libbspExt compile? I don't see any output.
I have never understood why you all didn't work to
get the libbspExt capabilities into the PIC interrupt
model code. In particular, the new shared implementation
by Sebastian Huber.
FWIW I am not even sure at this point what capabilities
it offers that you don't have in the shared implementation
of the PIC interrupt model.
--joel
On 09/11/2012 10:17 AM, Eric Norum wrote:
AFAIK the RTEMS-4.11 stuff is still a development branch.
I just checked and found that I could use EPICS/RTEMS-4.10 on my OS X "Mountain Lion" host as follows:
1) Download and install gmp-5.0.5, mpc-1.0., mpfr-3.1.1, automake-1.11.1and autoconf-2.68 with PREFX=/usr/llocal/rtems/rtems-4.10.
2) Run the getAndBuildTools-4.10.sh script (attached).
3) Downloaded and unpacked rtems-4.10.2.tar.bz2 and rtems-addon-packages-4.10.2.tar.bz2 from http://www.rtems.org/ftp/pub/rtems/4.10.2/
4) Ran the bootstrap script in the top RTEMS source directory.
5) Build RTEMS:
/usr/local/rtems/rtems-4.10/src/rtems-4.10.2/configure --prefix=/usr/local/rtems/rtems-4.10 --enable-cxx --disable-rdbg --enable-tests=samples --enable-networking --enable-posix --target=powerpc-rtems4.10 '--enable-rtemsbsp=mvme3100 mvme2100 beatnik'
make -w
make -w install
6) Build the RTEMS add-on packages (to get readline)
7) Build 'extended BSP' support.
8) Build EPICS with the attached configure/os/CONFIG_SITE.Common.RTEMS
I tried the above with the RTEMS-4.11 stuff but ran into problems at step (7) -- I couldn't get the the 'libbspExt' stuff to build.  I don't think that there's anything wrong with the source, just the Makefile arrangements seem to have changed between 4.10 and 4.11.  It would be nice if the bspExt stuff could migrate to RTEMS itself….
Joel Sherrill, Ph.D.             Director of Research&  Development
[email protected]        On-Line Applications Research
Ask me about RTEMS: a free RTOS  Huntsville AL 35805
    Support Available             (256) 722-9985
Re: Compilation error EPICS for RTEMS Bruno Seiva Martins
Re: Compilation error EPICS for RTEMS Eric Norum
Prev: Re: ISEG EHS device support on the Raspberry Pi Computer Eric Norum
Next: RE: GigE Vision & GeniCam standard SDK (areaDetector) Ahed Aladwan
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Compilation error EPICS for RTEMS Eric Norum
Next: Re: Compilation error EPICS for RTEMS Bruno Seiva Martins
