1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: ISEG EHS device support on the Raspberry Pi Computer
To: [email protected]
Cc: [email protected]
Date: Tue, 11 Sep 2012 08:22:49 -0700
On Sep 11, 2012, at 7:02 AM, [email protected] wrote:
> I would have thought the "%8R" stream device converter would do the job.
I don't believe that it would.  The '%R' converter is 'too raw'.
For example, writing using %4R would send the four bytes, but wouldn't convert them to two 16-bit base-16 strings as described below.
> -----Original Message-----
> From: [email protected] [mailto:[email protected]] On Behalf Of Florian Feldbauer
> Sent: 11 September 2012 14:46
> To: Mark Rivers; EPICS tech talk
> Hi,
> thanks for your replies. Writing an asyn driver seems a pretty good idea.
> But for the EHS modules from ISEG, I don't think StreamDevice would be
> feasible.
> Maybe I'm biased due to our old CAN interfaces.
> Up to now we used asynDriver and StreamDevice to control these modules.
> But our CAN interfaces were in principal
> RS232- or USB-to-CAN converters which read/write ASCII-Strings. Every
> single byte from the can frame was coded as 2 digit hex value
> separated by blanks (somethink like "ab 24 1f 05").
> The EHS modules use 32bit float values for currents, voltages and
> temperatures. So we needed to convert a IEEE754 32bit float
> to something which stream could write like "%02x %02x %02x %02x", or the
> other way around.
> Therefore I think a device support for this modules would be more feasible.
> Sure, if we write our own asyn driver one could think about an interface
> which reads/writes bitstreams, so we don't need such a conversion.
> Best regards,
> Florian
Eric Norum
[email protected]
ISEG EHS device support on the Raspberry Pi Computer Florian Feldbauer
RE: ISEG EHS device support on the Raspberry Pi Computer Mark Rivers
Re: ISEG EHS device support on the Raspberry Pi Computer Florian Feldbauer
RE: ISEG EHS device support on the Raspberry Pi Computer peter.owens
Prev: Re: Compilation error EPICS for RTEMS Eric Norum
Next: Re: Compilation error EPICS for RTEMS Joel Sherrill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: ISEG EHS device support on the Raspberry Pi Computer Florian Feldbauer
Next: Re: ISEG EHS device support on the Raspberry Pi Computer Florian Feldbauer
