1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: First Use Of 3.14.12.2 - target builds try to produce code for host also
To: EPICS Tech Talk <[email protected]>
Date: Fri, 05 Oct 2012 23:14:51 +0200
On Fri Oct 05 2012 22:49:54 GMT+0200 (CEST), Duane Voy <[email protected]> wrote:
I have built 3.14.12.2 on linux-x86 host for cross development to vxWorks-ppc604_long targets.
When I do 'gmake vxWorks-ppc604_long' the make system tries to produce code for linux-x86 as well, which is doomed to failure with code referencing VxWorks headers.
This behavior is different from any that I have seen in versions <= 3.14.10.
I have been reading documentation and googling and greping, and have tried everything I can think of to make CROSS_COMPILER_TARGET_ARCHS be -just- vxWorks-ppc604_long.  All with no luck.
Hi Duane,
this behavior change has been documented in the release notes [1], see "Build system dependency change" in the section for 3.14.11.
The key is to change the Makefiles for vxWorks-only modules to build vxWorks-only stuff only for vxWorks. (Not as trivial as it sounds.)
In most cases this involves moving definitions e.g. from LIBRARY to LIBRARY_vxWorks, from PROD to PROD_vxWorks etc. - see the chapter "Build Facility" (paragraph "Makefile definitions") in the App Developers Guide.
HTH,
~Ralph
[1] http://www.aps.anl.gov/epics/base/R3-14/12-docs/RELEASE_NOTES.html
First Use Of 3.14.12.2 - target builds try to produce code for host also Duane Voy
Prev: Re: Triggered autosave on exit Ralph Lange
Next: Re: EPICS 3.15.0 incompatible make rules Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: First Use Of 3.14.12.2 - target builds try to produce code for host also Duane Voy
Next: areaDetector R1-8 released Mark Rivers
