Hi Ralph,
On 2012-10-05 Ralph Lange wrote:
> I suggest we add a bunch of variables named ...CLEAN, that users can set
> to add files that they wish to be cleaned.
> Keep them separate for the different cleans (clean vs. realclean etc.).
Actually Janet already did that, but with just one variable called CLEANS.
Applications can handle this in a backwards-compatible manner like this:
CLEANS += <list of files to be cleaned>
ifndef BASE_3_15
clean::
$(RM) $(CLEANS)
endif
I have just added the above to the Release Notes on the 3.15 branch since we
don't seem to have documented the change yet. Note that the above rule is not
compatible with the 3.13 build system, IIRC you would need to use a single-
colon rule there instead (student exercise).
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
- Re: EPICS 3.15.0 incompatible make rules Benjamin Franksen
- EPICS 3.15.0 incompatible make rules Dirk Zimoch
- Re: EPICS 3.15.0 incompatible make rules Ron Sluiter
- Re: EPICS 3.15.0 incompatible make rules Ralph Lange
Re: First Use Of 3.14.12.2 - target builds try to produce code for host also Ralph Lange
areaDetector R1-8 released Mark Rivers
<2012>
2025
2026
<2012>
2025
2026
