1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS 3.15.0 incompatible make rules
To: <[email protected]>
Date: Mon, 8 Oct 2012 13:29:08 +0200
Am Montag, 8. Oktober 2012, 02:48:17 schrieb Andrew Johnson:
> On 2012-10-07 Benjamin Franksen wrote:
> > BTW, on my 64 bit linux (debian testing) with base-3.15.0.1, I get an
> > inexplicable
> > ben@sarun[1]: .../seq/branch-2-1 > make -sj
> > make[3]: Circular libseqDev.so. <-
> > ../../../lib/linux-x86_64/libseqDev.so. dependency dropped.
> > This did not happen with 3.14, I guess the new base rules add some extra
> > dependencies. Any idea how to fix that?
> This may be something to do with the patch mentioned below, or it might be
> related to a change in $(DEP) dependency rules; if it still occurs after
> applying the patch get back to me.
> > Also strange: all the generated shared libraries (.so) have an extra '.'
> > appended:
> Please read the Known Problems for 3.15 and apply the patch to fix that.
I applied the patches and it looks good now. The 'circular dependency' is
gone, too. I will apply the clean rule adjustment as you recommended and
create a new 3.15 compatible release.
Thanks
Ben Franksen
()  ascii ribbon campaign - against html e-mail
/\  www.asciiribbon.org   - against proprietary attachments
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
EPICS 3.15.0 incompatible make rules Dirk Zimoch
Re: EPICS 3.15.0 incompatible make rules Benjamin Franksen
Re: EPICS 3.15.0 incompatible make rules Andrew Johnson
Prev: RE: EPICS 3.15.0 incompatible make rules Andrew C. Starritt
Next: Re: EPICS 3.15.0 incompatible make rules Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS 3.15.0 incompatible make rules Benjamin Franksen
Next: Re: EPICS 3.15.0 incompatible make rules Dirk Zimoch
