1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: EPICS 3.15.0 incompatible make rules
To: Andrew Johnson <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 8 Oct 2012 12:23:22 +1100
Hi Andrew, Benjamin,
> > (A somewhat strange effect is that if I set LANG=C, then I get no
> such
> > message!)
> I can't explain that...
I think I can. Try this:
[starritt@redgum]$ touch a z A Z _
[starritt@redgum]$ ls -l
-rw-rw-r-- 1 starritt starritt 0 Oct  8 12:03 _
-rw-rw-r-- 1 starritt starritt 0 Oct  8 12:03 a
-rw-rw-r-- 1 starritt starritt 0 Oct  8 12:03 A
-rw-rw-r-- 1 starritt starritt 0 Oct  8 12:03 z
-rw-rw-r-- 1 starritt starritt 0 Oct  8 12:03 Z
[starritt@redgum]$ export LANG=C
The order that ls lists directories and files is affected by
the LANG environment variable.
With no explicit dependency rule, items added to DIRS with
DIRS := $(DIRS) $(filter-out $(DIRS), $(wildcard *App))
are build in the same order as ls lists them. I think there must be a
depencency order that is implicity being catered for when LANG is set
to C.
Regards
Andrew Starritt | Principal Controls Engineer | Australian Synchrotron
p: (03) 8540 4164 | f: (03) 8540 4200
[email protected] | www.synchrotron.org.au
800 Blackburn Road, Clayton, Victoria 3168
> -----Original Message-----
> From: [email protected] [mailto:tech-talk-
> [email protected]] On Behalf Of Andrew Johnson
> Sent: Monday, 8 October 2012 11:48 AM
> To: [email protected]
> Subject: Re: EPICS 3.15.0 incompatible make rules
> Hi Benjamin,
> On 2012-10-07 Benjamin Franksen wrote:
> > > CLEANS += <list of files to be cleaned>
> > > ifndef BASE_3_15
> > > clean::
> > >       $(RM) $(CLEANS)
> > > endif
> > What about support modules like seq? I hope the double colon rule
> means
> >  that multiple clean rules (from multiple support modules) are not in
> >  conflict with each other, but just wanted to make sure. If yes, I
> will
> >  change the sequencer build rules accordingly.
> The sequencer build will need to adopt the above approach to be
> compatible
> with the 3.15 build rules.  The double-colon rule is there for
> backwards
> compatibility with 3.14 (that's an if-not-defined BASE_3_15 condition,
> so it
> only applies for rules from older versions of Base); 3.14 uses double-
> colon
> rules for clean.  I think 3.13 used a single-colon rules.
> > BTW, on my 64 bit linux (debian testing) with base-3.15.0.1, I get an
> > inexplicable
> > ben@sarun[1]: .../seq/branch-2-1 > make -sj
> > make[3]: Circular libseqDev.so. <- ../../../lib/linux-
> x86_64/libseqDev.so.
> > dependency dropped.
> > This did not happen with 3.14, I guess the new base rules add some
> extra
> > dependencies. Any idea how to fix that?
> This may be something to do with the patch mentioned below, or it might
> be
> related to a change in $(DEP) dependency rules; if it still occurs
> after
> applying the patch get back to me.
> such
> > message!)
> > Also strange: all the generated shared libraries (.so) have an extra
> > appended:
> Please read the Known Problems for 3.15 and apply the patch to fix
> that.
> HTH,
> - Andrew
> Never interrupt your enemy when he is making a mistake.
> -- Napoleon Bonaparte
Re: EPICS 3.15.0 incompatible make rules Benjamin Franksen
EPICS 3.15.0 incompatible make rules Dirk Zimoch
Re: EPICS 3.15.0 incompatible make rules Andrew Johnson
Prev: Re: EPICS 3.15.0 incompatible make rules Andrew Johnson
Next: Re: EPICS 3.15.0 incompatible make rules Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
