1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS 3.15.0 incompatible make rules
To: <[email protected]>
Date: Mon, 8 Oct 2012 13:37:37 +0200
Am Montag, 8. Oktober 2012, 03:23:22 schrieb Andrew C. Starritt:
> > > (A somewhat strange effect is that if I set LANG=C, then I get no
> > such
> > > message!)
> > I can't explain that...
> I think I can. Try this:
> [starritt@redgum]$ touch a z A Z _
> [starritt@redgum]$ ls -l
> -rw-rw-r-- 1 starritt starritt 0 Oct  8 12:03 _
> -rw-rw-r-- 1 starritt starritt 0 Oct  8 12:03 a
> -rw-rw-r-- 1 starritt starritt 0 Oct  8 12:03 A
> -rw-rw-r-- 1 starritt starritt 0 Oct  8 12:03 z
> -rw-rw-r-- 1 starritt starritt 0 Oct  8 12:03 Z
> [starritt@redgum]$ export LANG=C
> The order that ls lists directories and files is affected by
> the LANG environment variable.
> With no explicit dependency rule, items added to DIRS with
> DIRS := $(DIRS) $(filter-out $(DIRS), $(wildcard *App))
> are build in the same order as ls lists them. I think there must be a
> depencency order that is implicity being catered for when LANG is set
> to C.
Yeah, that's a probable explanation, some variable uses wildcards or $(shell
ls) or whatever, and rules are not fully order-independent.
Anyway, the problem disappeared after I applied the known problem patches, so
I guess I'll leave it at that...
Cheers
Ben Franksen
()  ascii ribbon campaign - against html e-mail
/\  www.asciiribbon.org   - against proprietary attachments
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
EPICS 3.15.0 incompatible make rules Dirk Zimoch
Re: EPICS 3.15.0 incompatible make rules Andrew Johnson
RE: EPICS 3.15.0 incompatible make rules Andrew C. Starritt
Prev: Re: EPICS 3.15.0 incompatible make rules Benjamin Franksen
Next: Re: EPICS 3.15.0 incompatible make rules Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: EPICS 3.15.0 incompatible make rules Andrew C. Starritt
Next: Re: EPICS 3.15.0 incompatible make rules Benjamin Franksen
