Subject: installing EPICS
To: [email protected]
Date: Tue, 23 Oct 2012 23:59:07 -0400
Ive been trying all types of ways to install EPICS on my mac OS 10.8.2 with no luck... I have a laundry list of problems but Ive been informed that the first problem to tackle is getting epics base working... every time i try to run 'python setup.py install' from the epics base directory it gives me this code :
new-host:base-3.14.12.2 jamesbryant$ export EPICS_BASE=/Users/jamesbryant/Desktop/base-3.14.12.2
new-host:base-3.14.12.2 jamesbryant$ python setup.py install
python: can't open file 'setup.py': [Errno 2] No such file or directory
new-host:base-3.14.12.2 jamesbryant$ python3 setup.py install
/Library/Frameworks/Python.framework/Versions/3.2/Resources/Python.app/Contents/MacOS/Python: can't open file 'setup.py': [Errno 2] No such file or directory
new-host:base-3.14.12.2 jamesbryant$ sudo setup.py install
Password:
sudo: setup.py: command not found
# before this I input:
new-host:base-3.14.12.2 jamesbryant$ export EPICS_HOST_ARCH=darwin-x86
new-host:base-3.14.12.2 jamesbryant$ make
# ... and it spit out a bunch of code, which ended with:
mkdir ../../../lib/perl/5.12.4
mkdir ../../../lib/perl/5.12.4/darwin-thread-multi-2level
Installing script ../../../bin/darwin-x86/cainfo.pl
Installing script ../../../bin/darwin-x86/caput.pl
Installing script ../../../bin/darwin-x86/caget.pl
Installing script ../../../bin/darwin-x86/capr.pl
Installing script ../../../bin/darwin-x86/camonitor.pl
rm -f CA.html
podchecker ../CA.pm && pod2html --infile=../CA.pm --outfile=CA.html
../CA.pm pod syntax OK.
Installing html ../../../html/./CA.html
rm CA.html
any ideas???
- Thanks!
Re: installing EPICS J. Lewis Muir
Re: installing EPICS Matt Newville
Prev: Lambda EMS mismatch errors Anthony Andrews
Next: Re: Lambda EMS mismatch errors Fabian S.
Prev: Re: Lambda EMS mismatch errors Eric Norum
Next: Re: installing EPICS J. Lewis Muir
