Subject: Re: installing EPICS
To: James Bryant <[email protected]>
Cc: [email protected]
Date: Wed, 24 Oct 2012 09:48:10 -0500
On 10/23/12 10:59 PM, James Bryant wrote:
> Ive been trying all types of ways to install EPICS on my mac OS 10.8.2 with
> no luck... I have a laundry list of problems but Ive been informed that the
> first problem to tackle is getting epics base working... every time i try
> to run 'python setup.py install' from the epics base directory it gives me
> this code :
> new-host:base-3.14.12.2 jamesbryant$ export
> EPICS_BASE=/Users/jamesbryant/Desktop/base-3.14.12.2
> new-host:base-3.14.12.2 jamesbryant$ python setup.py install
> python: can't open file 'setup.py': [Errno 2] No such file or directory
> new-host:base-3.14.12.2 jamesbryant$ python3 setup.py install
> /Library/Frameworks/Python.framework/Versions/3.2/Resources/Python.app/Contents/MacOS/Python:
> new-host:base-3.14.12.2 jamesbryant$ sudo setup.py install
> Password:
> sudo: setup.py: command not found
Hi, James.
That won't work.  What are you trying to install?  Running
"python setup.py install" in the EPICS Base root directory won't
work.  Where did you get instructions to do that?
> # before this I input:
> new-host:base-3.14.12.2 jamesbryant$ export EPICS_HOST_ARCH=darwin-x86
> new-host:base-3.14.12.2 jamesbryant$ make
> # ... and it spit out a bunch of code, which ended with:
> mkdir ../../../lib/perl/5.12.4
> mkdir ../../../lib/perl/5.12.4/darwin-thread-multi-2level
> Installing script ../../../bin/darwin-x86/cainfo.pl
> Installing script ../../../bin/darwin-x86/caput.pl
> Installing script ../../../bin/darwin-x86/caget.pl
> Installing script ../../../bin/darwin-x86/capr.pl
> Installing script ../../../bin/darwin-x86/camonitor.pl
> rm -f CA.html
> podchecker ../CA.pm && pod2html --infile=../CA.pm --outfile=CA.html
> ../CA.pm pod syntax OK.
> Installing html ../../../html/./CA.html
> rm CA.html
> any ideas???
This looks like you may have succeeded in building and
installing EPICS Base.
Lewis
installing EPICS James Bryant
Prev: Rotation image Widget patard
Next: Re: installing EPICS Matt Newville
Prev: installing EPICS James Bryant
