1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: streamDevice 32-bit hex value read problem
To: [email protected]
Date: Mon, 12 Nov 2012 14:21:00 -0600
I'm trying to read a 32-bit hex value like ffffffff ffffffff using
EPICS R3.14.12.2, streamDevice 2-5, and asyn 4-19 on 64-bit Linux OS.
When I read these values using the following protocol:
get_ilock {
	out "din";
	in "%(\$1FirstInterlockWord.VAL)8R ",
	   "%(\$1SecondInterlockWord.VAL)0R";
	ExtraInput = Ignore;
Both records are longin records and no matter if I use the 8R or 0R I
always get the same result:
 ID06ds:FirstInterlockWord      11/12/12 14:03:02.743812335 -2147483648
 ID06ds:SecondInterlockWord     11/12/12 14:03:02.743823268 -2147483648
Turns out that this is hex value 80000000
If I use a strngin record I can see that I'm getting the expected data.
Is this the largest value that I can read using streamDevice or is there
some other way that I should try to read these values?
Marty
RE: streamDevice 32-bit hex value read problem Allison, Stephanie
Re: streamDevice 32-bit hex value read problem Dirk Zimoch
Prev: RE: procServ softIOC server - V2.6.0 released Mark Rivers
Next: Re: strange EPICS glitch Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Senior Software Engineer needed at MSU's FRIB careers
Next: RE: streamDevice 32-bit hex value read problem Allison, Stephanie
