1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: streamDevice 32-bit hex value read problem
To: "'Martin L. Smith'" <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 12 Nov 2012 15:08:40 -0800
Hi Marty -
So you are reading 2 unsigned 32 bit integers into 2 longin records (and longin's are signed 32 bit integers even on 64bit machines).
Could you instead read into 2 ai records?  Or into A and B fields of an aSub record where FTA and FTB are "ULONG"?
Stephanie Allison
> -----Original Message-----
> From: [email protected] [mailto:tech-talk-
> [email protected]] On Behalf Of Martin L. Smith
> Sent: Monday, November 12, 2012 12:21 PM
> To: [email protected]
> Subject: streamDevice 32-bit hex value read problem
> I'm trying to read a 32-bit hex value like ffffffff ffffffff using
> EPICS R3.14.12.2, streamDevice 2-5, and asyn 4-19 on 64-bit Linux OS.
> When I read these values using the following protocol:
> get_ilock {
> 	out "din";
> 	in "%(\$1FirstInterlockWord.VAL)8R ",
> 	   "%(\$1SecondInterlockWord.VAL)0R";
> 	ExtraInput = Ignore;
> Both records are longin records and no matter if I use the 8R or 0R I
> always get the same result:
>   ID06ds:FirstInterlockWord      11/12/12 14:03:02.743812335 -2147483648
>   ID06ds:SecondInterlockWord     11/12/12 14:03:02.743823268 -2147483648
> Turns out that this is hex value 80000000
> If I use a strngin record I can see that I'm getting the expected data.
> Is this the largest value that I can read using streamDevice or is there
> some other way that I should try to read these values?
> Thanks,
> Marty
streamDevice 32-bit hex value read problem Martin L. Smith
Prev: Re: strange EPICS glitch Andrew Johnson
Next: question of Hytec 8516 added in synApps-5.3 李芳
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: streamDevice 32-bit hex value read problem Martin L. Smith
Next: Re: streamDevice 32-bit hex value read problem Dirk Zimoch
