1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: LeCroy DSO using VXI
To: EPICS Tech Talk <[email protected]>
Cc: Eric Norum <[email protected]>
Date: Thu, 13 Dec 2012 10:15:26 +0100
A short look at the scope with rpcinfo revealed the following information:
   Program Vers Proto   Port
    395183    1   tcp   1009
    395184    1   tcp   1009
    395183    1   udp   1006
    395184    1   udp   1006
Where
395184 -> 0x0607B0
395183 -> 0x0607AF
So SRQ handling (0x0607B1) is not supported on this device. Is there a way to disable it?
Re: LeCroy DSO using VXI Eric Norum
LeCroy DSO using VXI Jörn Wüstenfeld
Prev: Re: .PACT .TIME Pavel Maslov
Next: Re: .PACT .TIME Pavel Maslov
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: LeCroy DSO using VXI Eric Norum
Next: Re: LeCroy DSO using VXI Eric Norum
