SRQ handling is the other way around -- the IOC is the RPC server so I'm not sure that the rpcinfo results indicate a lack of SRQ support.
In any case, things should work fine (other than the annoying diagnostic messages on IOC startup) whether or not SRQs are support and/or properly configured.
Did you try adding the startup script commands and protocol terminator specifiers that I mentioned in my previous message?
On Dec 13, 2012, at 1:15 AM, Jörn Wüstenfeld <[email protected]> wrote:
> A short look at the scope with rpcinfo revealed the following information:
> Program Vers Proto Port
> 395183 1 tcp 1009
> 395184 1 tcp 1009
> 395183 1 udp 1006
> 395184 1 udp 1006
> Where
> 395184 -> 0x0607B0
> 395183 -> 0x0607AF
> So SRQ handling (0x0607B1) is not supported on this device. Is there a way to disable it?
Eric Norum
[email protected]
- LeCroy DSO using VXI Jörn Wüstenfeld
- Re: LeCroy DSO using VXI Eric Norum
- Re: LeCroy DSO using VXI Jörn Wüstenfeld
Re: Utilities for EPICS on Multi-Core Linux Ralph Lange
RE: EPICSPVFactory in CSS JavaScript Chen, Xihui
<2012>
2025
2026
<2012>
2025
2026
