1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Best practices for introducing new dot releases of modules.
Date: Wed, 20 Feb 2013 10:58:20 -0800
Hello all,
  I have a noobie EPICS build system question. What I am actually trying to do is to figure out how to introduce a new version of a module (for example, the sequencer, as it is widely used) with a minor bug fix. My users do not want me to patch in place; so I take seq-R2-0-11-lcls4  and create a new dot release of the sequencer – for example, seq-R2-0-11-lcls5. I change the IOC application to use the new version of the module. However, when I try to build it, I get
Definition of SNCSEQ_MODULE_VERSION conflicts with ASYN support.
In this application a RELEASE file defines
                SNCSEQ_MODULE_VERSION = seq-R2-0-11-lcls5
but ASYN at /afs/slac/g/lcls/epics/modules/R3-14-12/asyn/asyn-R4-17-RC1-lcls1 defines
                SNCSEQ_MODULE_VERSION = seq-R2-0-11-lcls4
Definition of SNCSEQ conflicts with ASYN support.
                SNCSEQ = /afs/slac/g/lcls/epics/modules/R3-14-12/seq/seq-R2-0-11-lcls5
                SNCSEQ = /afs/slac/g/lcls/epics/modules/R3-14-12/seq/seq-R2-0-11-lcls4
Definition of SNCSEQ conflicts with MOTOR support.
but MOTOR at /afs/slac/g/lcls/epics/modules/R3-14-12/motor/motor-R6-6-RC2-lcls1 defines
So, to test a dot release of the sequencer, should I rebuild all the other modules that the app depends on that also depend on the sequencer? We do maintain a shared repository of modules; so perhaps that’s the issue. Are there standard techniques people use to introduce new versions of modules?
Any help is appreciated.
Murali
RE: Best practices for introducing new dot releases of modules. Allison, Stephanie
Re: Best practices for introducing new dot releases of modules. Ron Sluiter
Re: Best practices for introducing new dot releases of modules. Andrew Johnson
Prev: trying to compile snmp for Wiener PL512 crate application James F Ross
Next: RE: Best practices for introducing new dot releases of modules. Allison, Stephanie
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: trying to compile snmp for Wiener PL512 crate application James F Ross
