Hi Murali,
On 2013-02-20 Shankar, Murali wrote:
> So, to test a dot release of the sequencer, should I rebuild all the other
> modules that the app depends on that also depend on the sequencer?
Yup, that's what you have to do to solve this properly. Although the new
version could be fully compatible with the old one, there is no way for the
build system to test that compatibility, so by default it enforces the safest
option, which is to not allow the build to continue. I added the module
checking mechanism because in the past linking incompatible modules together
has caused numerous some really strange and often extremely subtle bugs to
turn up here at APS, in some cases only being noticed days or even weeks after
we booted the IOC.
If you as the author of the IOC are certain that the changes did not involve
modifying any struct or class definitions, or changing any routines in an
incompatible way you can edit your application's configure/CONFIG_SITE file
and set CHECK_RELEASE to WARN (it also accepts NO but I don't recommend using
that) which will then allow the build to complete despite the warnings.
- Andrew
There is no such thing as a free lunch. When invited for lunch,
it is best to check if you are there to eat, or to be eaten.
-- Clive Robinson
- RE: Best practices for introducing new dot releases of modules. Shankar, Murali
- Best practices for introducing new dot releases of modules. Shankar, Murali
RE: Best practices for introducing new dot releases of modules. Allison, Stephanie
EDM Text Control Widget Motif behavior Isadoro Carlino
<2013>
2025
2026
<2013>
2025
2026
