1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Best practices for introducing new dot releases of modules.
To: "'Andrew Johnson'" <[email protected]>, "[email protected]" <[email protected]>, "Allison, Stephanie" <[email protected]>, "'Ron Sluiter'" <[email protected]>
Date: Wed, 20 Feb 2013 13:00:12 -0800
Got it. Thanks all for your help.
Murali
-----Original Message-----
Sent: Wednesday, February 20, 2013 11:58 AM
To: [email protected]
Cc: Shankar, Murali
Subject: Re: Best practices for introducing new dot releases of modules.
Hi Murali,
On 2013-02-20 Shankar, Murali wrote:
> So, to test a dot release of the sequencer, should I rebuild all the
> other modules that the app depends on that also depend on the sequencer?
Yup, that's what you have to do to solve this properly.  Although the new version could be fully compatible with the old one, there is no way for the build system to test that compatibility, so by default it enforces the safest option, which is to not allow the build to continue.  I added the module checking mechanism because in the past linking incompatible modules together has caused numerous some really strange and often extremely subtle bugs to turn up here at APS, in some cases only being noticed days or even weeks after we booted the IOC.
If you as the author of the IOC are certain that the changes did not involve modifying any struct or class definitions, or changing any routines in an incompatible way you can edit your application's configure/CONFIG_SITE file and set CHECK_RELEASE to WARN (it also accepts NO but I don't recommend using
that) which will then allow the build to complete despite the warnings.
- Andrew
There is no such thing as a free lunch.  When invited for lunch, it is best to check if you are there to eat, or to be eaten.
-- Clive Robinson
Best practices for introducing new dot releases of modules. Shankar, Murali
Re: Best practices for introducing new dot releases of modules. Andrew Johnson
Prev: EDM Text Control Widget Motif behavior Isadoro Carlino
Next: Re: gateway: strange configuration Pierrick Hanlet
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Best practices for introducing new dot releases of modules. Andrew Johnson
Next: EDM Text Control Widget Motif behavior Isadoro Carlino
