1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Best practices for introducing new dot releases of modules.
To: "Shankar, Murali" <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 20 Feb 2013 11:36:09 -0800
Hi Murali,
When I download a module that requires SNCSEQ (like asyn) and I don't plan to use the sequence that comes with that module (which is usually true in my case), I remove the SNCSEQ dependency from the RELEASE file of that module and comment out any reference to the sequence (if necessary).  Sometimes, a module is smart enough to know not to build the sequence if SNCSEQ is not defined.
Stephanie Allison
> -----Original Message-----
> From: [email protected] [mailto:[email protected]] On Behalf
> Of Shankar, Murali
> Sent: Wednesday, February 20, 2013 10:58 AM
> To: [email protected]
> Subject: Best practices for introducing new dot releases of modules.
> Hello all,
>   I have a noobie EPICS build system question. What I am actually trying to do is to figure
> out how to introduce a new version of a module (for example, the sequencer, as it is
> widely used) with a minor bug fix. My users do not want me to patch in place; so I take
> seq-R2-0-11-lcls4  and create a new dot release of the sequencer - for example, seq-R2-0-
> 11-lcls5. I change the IOC application to use the new version of the module. However,
> when I try to build it, I get
> Definition of SNCSEQ_MODULE_VERSION conflicts with ASYN support.
> In this application a RELEASE file defines
>                 SNCSEQ_MODULE_VERSION = seq-R2-0-11-lcls5
> but ASYN at /afs/slac/g/lcls/epics/modules/R3-14-12/asyn/asyn-R4-17-RC1-lcls1 defines
>                 SNCSEQ_MODULE_VERSION = seq-R2-0-11-lcls4
> Definition of SNCSEQ conflicts with ASYN support.
>                 SNCSEQ = /afs/slac/g/lcls/epics/modules/R3-14-12/seq/seq-R2-0-11-lcls5
>                 SNCSEQ = /afs/slac/g/lcls/epics/modules/R3-14-12/seq/seq-R2-0-11-lcls4
> Definition of SNCSEQ conflicts with MOTOR support.
> but MOTOR at /afs/slac/g/lcls/epics/modules/R3-14-12/motor/motor-R6-6-RC2-lcls1
> defines
> So, to test a dot release of the sequencer, should I rebuild all the other modules that the
> app depends on that also depend on the sequencer? We do maintain a shared repository of
> modules; so perhaps that's the issue. Are there standard techniques people use to introduce
> new versions of modules?
> Any help is appreciated.
> Regards,
> Murali
Best practices for introducing new dot releases of modules. Shankar, Murali
Prev: Best practices for introducing new dot releases of modules. Shankar, Murali
Next: Re: Best practices for introducing new dot releases of modules. Ron Sluiter
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
