1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Problem when cross-compiling epics base for vxWorks5.5 on win32-x86
To: <[email protected]>
Date: Fri, 22 Feb 2013 23:23:36 +0800
Hello,
I follow the "Microsoft API" method rather than cygwin method of this link to install epics3.14.12.1 on win32-x86 platform.
Without cross-compiling, it is OK. However, with the cross-compiling for vxWorks, it complains as follows,
make -C ./cap5 install
make[2]: Entering directory `D:/base-3.14.12.1/src/cap5'
perl ../../bin/win32-x86/makeMakefile.pl O.win32-x86 ../../..
perl ../../bin/win32-x86/makeMakefile.pl O.vxWorks-mpc8572 ../../..
perl -MExtUtils::Command -e mkpath O.Common
make -C O.win32-x86 -f ../Makefile TOP=../../.. T_A=win32-x86 install
make[3]: Entering directory `D:/base-3.14.12.1/src/cap5/O.win32-x86'
perl -MExtUtils::Command -e rm_f CA.html
podchecker ../CA.pm && pod2html --infile=../CA.pm --outfile=CA.html
bash.exe: warning: could not find /tmp, please create!
/cygdrive/d/Tornado2.2/host/x86-win32/bin/sh: podchecker: command not found
make[3]: *** [CA.html] error 127
make[3]: Leaving directory `D:/base-3.14.12.1/src/cap5/O.win32-x86'
make[2]: *** [install.win32-x86] error 2
make[2]: Leaving directory `D:/base-3.14.12.1/src/cap5'
make[1]: *** [cap5.install] error 2
make[1]: Leaving directory `D:/base-3.14.12.1/src'
make: *** [src.install] error 2
make: Leaving directory `D:/base-3.14.12.1'
File CONFIG.Common.vxWorks-mpc8572 is provided, and the configuration is as follows,
CROSS_COMPILER_TARGET_ARCHS=vxWorks-mpc8572
CROSS_COMPILER_HOST_ARCHS=win32-x86
VXWORDS_VERSION=5.5
WIND_BASE=D:\Tornado2.2
Though I try not to use cygwin, it seems to be related to it, and how can I solve this problem?
Lin Wang
Re: Problem when cross-compiling epics base for vxWorks5.5 on win32-x86 Andrew Johnson
Prev: RE: EPICS Modbus module + PLC Lecorche Eric
Next: Re: Problem when cross-compiling epics base for vxWorks5.5 on win32-x86 Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS Modbus module + PLC Pavel Maslov
