Subject: |
Re: Problem when cross-compiling epics base for vxWorks5.5 on win32-x86 |
Andrew Johnson <[email protected]> |
To: |
[email protected] |
Date: |
Fri, 22 Feb 2013 10:02:51 -0600 |
On 2013-02-22 王林 wrote:
> I follow the "Microsoft API" method rather than cygwin method of this link
> to install epics3.14.12.1 on win32-x86 platform.
> http://www.aps.anl.gov/epics/base/win32.php
> Without cross-compiling, it is OK. However, with the cross-compiling for
> vxWorks, it complains as follows,
> make[3]: Entering directory `D:/base-3.14.12.1/src/cap5/O.win32-x86'
> perl -MExtUtils::Command -e rm_f CA.html
> podchecker ../CA.pm && pod2html --infile=../CA.pm --outfile=CA.html
> bash.exe: warning: could not find /tmp, please create!
> /cygdrive/d/Tornado2.2/host/x86-win32/bin/sh: podchecker: command not found
> Though I try not to use cygwin, it seems to be related to it, and how can I
> solve this problem?
The error being reported is that GNUmake can't find the program 'podchecker'
which should be part of your Perl installation. However by this point in the
build it has already compiled and installed everything that can be built on
Windows, so you can ignore this error. If you don't want to see it in the
future, you can comment out this line from the base/src/Makefile:
DIRS += cap5
The reason why this looks like a Cygwin problem is that the shell that is
trying to run the podchecker command was built (by Wind River as part of
Tornado 2.2) using Cygwin. Your EPICS binaries will not require cygwin to
work.
- Andrew
There is no such thing as a free lunch. When invited for lunch,
it is best to check if you are there to eat, or to be eaten.
-- Clive Robinson
- Re: Problem when cross-compiling epics base for vxWorks5.5 on win32-x86 Dirk Zimoch
- Problem when cross-compiling epics base for vxWorks5.5 on win32-x86 王林
Re: EPICS Modbus module + PLC Paul Nord
<2013>
2025
2026
<2013>
2025
2026
