1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problem when cross-compiling epics base for vxWorks5.5 on win32-x86
To: [email protected]
Date: Mon, 25 Feb 2013 15:51:53 +0100
On 22.02.2013 17:02, Andrew Johnson wrote:
The error being reported is that GNUmake can't find the program 'podchecker'
which should be part of your Perl installation.  However by this point in the
build it has already compiled and installed everything that can be built on
Windows, so you can ignore this error.  If you don't want to see it in the
future, you can comment out this line from the base/src/Makefile:
     DIRS += cap5
- Andrew
I had to comment out cap5 for several cross linux architectures. (which I build as "HOST" architecture in order to have caget and friends.) Also if the compiler you use to build EPICS is not the one that was used to build perl you get into trouble.
Do we really need cap5 in EPICS base? I would like to see it in a separate module.
Dirk
Re: Problem when cross-compiling epics base for vxWorks5.5 on win32-x86 J. Lewis Muir
Re: Problem when cross-compiling epics base for vxWorks5.5 on win32-x86 Andrew Johnson
Problem when cross-compiling epics base for vxWorks5.5 on win32-x86 王林
Prev: Re: Problem when loading epics3.14.12.1 application to vxWorks5.5/MPC8572 Dirk Zimoch
Next: Re: Problem when cross-compiling epics base for vxWorks5.5 on win32-x86 J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Problem when cross-compiling epics base for vxWorks5.5 on win32-x86 Andrew Johnson
